belt tension - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 24 Old 02-10-2019, 09:13 PM Thread Starter
ok gotcha thank you!
Nick Amb is offline
post #12 of 24 Old 02-10-2019, 09:19 PM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 75
Likes (Received): 123
Originally Posted by Nick Amb View Post
Hi. New forum user. I have an 826 old school machine. I had my local small engine guy replace a blown engine on it, runs awesome. One problem. The impeller and augers keep running even when disengaged. My safety hand grips aren't operational. I'd like to make whatever adjustments needed so that when it is disengaged, it is disengaged. Any help with adjustments, appreciate it.
Nick what model do you have throw some model numbers out there.....The blower # not 826 the actual model #itself and then your newer engine numbers.......If you want.
Helps the forum help you!!!!
Drop a pic if you can.....
Welcome by the way!!!!!
SimplicitySolid22 is offline
post #13 of 24 Old 02-10-2019, 09:21 PM
Thanks (Given): 141
Likes (Given): 415
Likes (Received): 739
And if you're unsure of the best approach, posting pictures of the area (including the adjuster) could help.
post #14 of 24 Old 02-10-2019, 11:44 PM Thread Starter
Ok jd SN is blacked out almost. Is it stamped anywhere other than the tag?
ID:	153329   Click image for larger version
ID:	153331   Click image for larger version
Nick Amb is offline
post #15 of 24 Old 02-10-2019, 11:45 PM Thread Starter
Jd plate
Nick Amb is offline
post #16 of 24 Old 02-11-2019, 02:49 AM
Likes (Given): 75
Nick is that black bracket in photo suppose to be there after pulleys and before chute in photo????
It looks like to me the engine sheave/pulley needs to go towards the chute a wee bit.
Your drive belt has a groove in it looks like it is misaligned.
You should probably replace that belt. It looks like tension pulleys are ahead of(more towards auger housing) than engine pulley. Engine pulley belt slots should be centered over drive plate & auger plate(big silver discs belts go on inside blower).
Can you take a couple picture of the idler pulleys from the side at eye level...same level across top of belts but not too close if ya get me???
post #17 of 24 Old 02-11-2019, 09:13 AM Thread Starter
Yes I sure can..off to work now. The black bracket is supposed to be there. I am thinking the belt guide might be too tight.
Nick Amb is offline
post #18 of 24 Old 02-11-2019, 10:43 AM
Thanks (Given): 65
Thanks (Received): 121
Likes (Given): 96
Likes (Received): 147
I think you are right about the misalignment. Looks like a one piece crank wheel drive pulley and impeller pulley, so a spacer on engine side of the pulley assembly would align the both pulleys with their idler pulleys.
Town is online now
post #19 of 24 Old 02-11-2019, 12:31 PM
Thanks (Received): 44
Likes (Received): 114
By the look of the photos, it kinda looks like the engine is not sitting square to the rest of the machine. Almost looks like it is sitting cocked to the left at pulley end. I see someone replaced the motor, the first thing I would do loosen the engine and see if you can line everything up with the holes that are currently used, and if not look at what it would take to make the holes to where the engine and all pulleys line up. I would do this before trying to add spacers or bending things to fit.
Photos can be deceiving but with your problem and what was done I think most of the problem is engine alignment.
Lottstodo is offline
Thanks Cutter thanked for this post
Likes Cutter liked this post
post #20 of 24 Old 02-11-2019, 01:22 PM
Cutter's Avatar
Thanks (Received): 14
Likes (Given): 117
I totally agree. I believe the engine is not sitting where it needs to be. Loosen and adjust the engine block, and I think it will greet you with a big smile.
Anytime,anyone has changed, altered, or fixed a machine, always look in the area of their repair. I had a A/C Compressor Clutch in an 84 Olds Cutlass fly apart and destroy my hood because a mechanic didn't replace a split ring properly. Always check to see if the problem is a recent repair.
Life is short, so if you don't have the strength to laugh at yourself,
call me.....I'll laugh at you!
2014 Ariens Deluxe 28 with 291 CC Engine
2011 John Deere JS36 Self Propelled Mower
Too many Craftsman Mechanic/Yard tools to mention
Cutter is offline
Similar Threads
New Engine Belt Has Constant Tension - Smaller Tension Pulley? WalkThisWhey Re-Powering 7 09-30-2018 10:47 PM
All belts should be measured & a primer on belts JLawrence08648 Snowblower Repairs and Maintenance Forum 1 02-11-2017 04:30 PM
Too much tension on auger belt? ssiddall Snowblower Repairs and Maintenance Forum 13 12-18-2016 12:36 PM
Auger Idler Tension Pulley Smoking My New Belt mzblues1 Snowblower Repairs and Maintenance Forum 36 02-19-2016 07:55 AM
Craftsman drive belt idler tension RickH Snowblower Repairs and Maintenance Forum 8 02-09-2014 10:59 PM
