belt tension - Page 3 - Snowblower Forum : Snow Blower Forums
post #21 of 24 Old 02-11-2019, 01:49 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 77
Likes (Given): 77
Likes (Received): 127
Listen to the boys that makes sense to me as well engine looks off to left and would account for belts being misaligned also. Even if you straighten that engine pulley it looks as though it still needs to be adjusted toward front of SB a bit. Although as Lotts and Cutter said if you loosen engine bolts and try not to only straighten the engine left to right you might be able to shift it forward a bit too. As others have also stated whomever did the engine swap did not take too much care....Rush job not done well.
Measure twice cut once!!!!
Belt guide would not put a groove in your drive belt it is the Drive tension pulley making that groove in the middle of your drive belt due to engine sheave/pulley being misaligned.
SimplicitySolid22 is offline
post #22 of 24 Old 02-11-2019, 07:03 PM Thread Starter
I got it. Moved the guide just a smidge. The grove in the one belt is a my bad, before new Motor I had the belt wrong...here are pics and a short vid
ID:	153377   Click image for larger version
ID:	153379   Click image for larger version
Nick Amb is offline
post #23 of 24 Old 02-11-2019, 07:04 PM Thread Starter
Nick Amb is offline
post #24 of 24 Old 02-12-2019, 07:14 PM
Thanks (Given): 63
Likes (Given): 77
Hey alright...Glad to see...
Similar Threads
New Engine Belt Has Constant Tension - Smaller Tension Pulley? WalkThisWhey Re-Powering 7 09-30-2018 10:47 PM
All belts should be measured & a primer on belts JLawrence08648 Snowblower Repairs and Maintenance Forum 1 02-11-2017 04:30 PM
Too much tension on auger belt? ssiddall Snowblower Repairs and Maintenance Forum 13 12-18-2016 12:36 PM
Auger Idler Tension Pulley Smoking My New Belt mzblues1 Snowblower Repairs and Maintenance Forum 36 02-19-2016 07:55 AM
Craftsman drive belt idler tension RickH Snowblower Repairs and Maintenance Forum 8 02-09-2014 10:59 PM
