44 Snowblower worm gear needed - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 02-16-2019, 06:41 PM Thread Starter
Hello all, I'm searching to find a replacement worm gear for the gearbox on my 44 snowblower attachment. I have already replaced the gearbox once at the cost of $500 bucks and I refuse to pay that again. I have searched the internet for a solution to this riddle but all I find are many others who have the same problem.
I am hoping to nail the fix down, once-and-for-all, and maybe this thread can be used for reference for others?
The mower I have is an X300. The blower attachment is a 44 snowblower.
I have my tail between my legs as to the reason I am in this situation but that is neither here-nor-there right now. I learned my lesson (and i thought I was old enough to stop learning this way).
This gear is made of one solid piece of bronze. I saw others with the 44" snowblower and their gear issue showed pictures with a center removed from the gear itself. I tried using my bushing remover and only split the center, spacer, portion of my gear.
Here is a picture of mine.
I made my measurements and wrote them down.
I'm hoping the pictures are not too big, I cut them to 35% of there original. If I need to make them smaller please let me know and I will.
What I don't know is the gear pitch. Maybe someone can help with that.
Since my gear is one piece, maybe I can find a center spacer and then a gear to fit over it? The auger shaft is 3/4 inch diameter.
I just find it odd there are so many people who have looked for this information and there hasn't been a solution found, or at least a solution which people are aware of.
Please help if you can. I'm in need to find an affordable solution and maybe I can answer some questions which I haven't thought of?
Best Regards
Name:	44 Blower data tag.jpg
ID:	153645   Click image for larger version
ID:	153647   Click image for larger version
Gonkulor is offline
Similar Threads
Worm gear swap? Nconroy1 Snowblower Repairs and Maintenance Forum 9 12-25-2015 11:30 AM
need a worm gear for a tractor mounted blower woodit Craftsman Snowblowers 3 12-23-2014 10:57 AM
Craftsman worm gear 40 tooth engine9 Snowblower Repairs and Maintenance Forum 0 12-04-2013 12:03 PM
Bolens 5210 Snowblower...1 forward gear, 3 reverse gears?! joebush44 Snowblower Repairs and Maintenance Forum 8 12-01-2013 09:05 PM
