LinkBack | Thread Tools |
2000 JD 282D - not blowing snow very far
Hey guys. Just wondering why in most snow conditions my blower isnt blowing snow as far as it used to. I do have quite a bit of gravel on my driveways and i have gone through a handful of shear pins. Just wondering if theres a certain orientation the auger blades need to be in for optimum snow throwing or if i need to look elsewhere.
Also is there a way to adjust the tensioner for the chute deflector so when i push deflector control handle fully forward the deflector opens up all the way. Right now i push handle forward and i get approx a 1/4" of cable slack and deflector opens approx 80-90%
Zach Hall
Iowa boy
2010 Ram 2500 Cummins Diesel - soot cooker and EGR deleted - tuned via EFILIVE
1983 chevy c10 - under the knife becoming a big tire pro street truck powered by a custom big inch small block
1939 Dodge D11 Luxury Liner Deluxe - all original pretty WWII car, records show 1 of 270 built before the war
1996 Polaris Indy Trail 488cc snowmobile
2000 Polaris Indy SKS 700cc snowmobile
2002 JD LT160 lawn tractor
1999ish JD 828D blower
Sponsored Links | |||
Advertisement |
Do you mean an 828D?
Yes. 828D. Sorry.
Zach Hall
Iowa boy
I would start with adjusting the auger belt. They loosen up/wear down over time.
+1 on the belt. Check the Auger Bearing as well. Your Deflector Cable is Frozen, Around $60 to replace according to my info. Might be able to work it free with penetrating oil.
Wheres the auger belt located and what tension am i looking for.
Zach Hall
Iowa boy
Remove the Belt Cover, and squeeze the Auger Caliper. Belt Should be Tight. If not, replace it or sometimes you can just adjust it. Also, Reach in and grab the Large Pulley the auger belt is on, and test it for Movement. It should not Move. If it moves, you need to replace the bearing.
Once the belts are tight,you might look at the gap between the impeller (fan) blades and the blower housing. Installing seals on the blades to close that gap improves impeller efficiency and throw distance - I've seen about 30% on my 63" tractor mount and closer to 40% on Snapper 28" walk behind. Most use rubber seals. I used UHMW-PE as snow doesn't tend to stick to it.
There are a number of how-to threads on modifying impellers.
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Upgrading your snowblower lights to LED lights | superedge88 | General Snowblower Discussion | 1351 | 12-05-2019 11:13 PM |
Night snow blowing | rnaude241 | General Snowblower Discussion | 32 | 02-03-2015 11:37 AM |
Snowblowing Rules of Thumb | SMFCPACFP | General Snowblower Discussion | 3 | 02-10-2012 09:57 AM |
Faceshield when blowing snow? | CharlesW | General Snowblower Discussion | 11 | 11-23-2010 07:06 PM |
Posting Rules | |
