TRS27 Headlight Wiring - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 09-29-2019, 06:40 PM Thread Starter
I am fixing my JD TRS27 for winter. Want to get the headlight working. There is no wires there. Where do the wires come from that goes to the headlight? Thanks in advance for the help!
esnb74 is offline
post #2 of 6 Old 09-30-2019, 09:30 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
From under the flywheel cover.
post #3 of 6 Old 10-03-2019, 02:31 PM Thread Starter
OK. I found a wire coming out the flywheel cover and it goes up to a spade terminal bracket on the carb mounting bracket with another spade connector (red wire that I added in pic below). The headlight has two connectors on it. Do I run this red wire to one side and just ground the other side? (Sorry for the sideways pic, it is right side up on my computer and can get it to show up correctly in this forum)
esnb74 is offline
post #4 of 6 Old 10-03-2019, 05:14 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3334
Likes (Received): 679
Welcome to SBF. "IF" you have the correct wire, they would come out of the recoil shroud on the gas tank side. I "think" the wires in your photo are kill switch wires that have no power. They just short the ignition coil to stop the motor.
Are you the original owner of the TRS? If you bought it used, the original owner may have switched motors to one that doesn't have an alternator for powering the light. Did the headlight work at one time?
post #5 of 6 Old 10-04-2019, 11:48 AM Thread Starter
Not the original owner. I'm the 2nd or 3rd. Machine shows very little use as the paint is still on the auger and inside the shoot. I will look a another time while installing a new carb this weekend and working on an rechargeable LED light idea.
esnb74 is offline
post #6 of 6 Old 10-04-2019, 12:41 PM
Thanks (Given): 275
Likes (Given): 3334
I just noticed the Craftsman label on the engine shroud. A John Deere wouldn't come with a Craftsman branded Tecumseh motor, so, I'm pretty sure the engine has been changed by a previous owner.
