JD 828D barely throws snow - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 12-03-2019, 04:31 PM Thread Starter
Hello out there!
My name is Jeff and I live in North, Central Connecticut near Springfield, MA. We just got hit with 12”-14” storm.
I joined after reading many articles from members to help determine what snow blower to buy. Ended up coming across an older John Deere 828D and couldn’t pass it up.
havent really tested the unit out until today and I was hoping someone could shed some light to a problem I am having. My snowblower is only throwing snow 3-4 feet when the auger is throwing to the right. Also, only 2-3 feet when pointed left and barely at all or clogging instantly when throwing in front.
The only thing i can think of is a loose belt (not very familiar with blowers outside of engine functionality). The other option is that the previous owner hit gravel and punched a few dents in the side of the unit inside where the fan spins but it really isnt bad looking. Where should i check first?
As soon as I figure out how, i will post a video or a pic of this happening.
Any help is greatly appreciated!
Thank you!
Jeffsayshi is offline
post #2 of 18 Old 12-03-2019, 04:41 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1026
Originally Posted by Jeffsayshi View Post
Hello out there!
My name is Jeff and I live in North, Central Connecticut near Springfield, MA. We just got hit with 12-14 storm.
I joined after reading many articles from members to help determine what snow blower to buy. Ended up coming across an older John Deere 828D and couldnt pass it up.
Thank you!
Welcome to SBF.
Pull the belt cover off and ck your auger belt(s). Youtube is your friend.
post #3 of 18 Old 12-03-2019, 11:41 PM Thread Starter
Micah,
Thank you for the tip! I’ll check it out this weekend. Will let you know.
Thanks Fat City thanked for this post
Likes Fat City liked this post
post #4 of 18 Old 12-04-2019, 07:41 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Engage the auger belt without the engine running and determine how loose tight the belt is. Then start the engine and engage the belt, see if the belt is flapping, there should be none or virtually none, maybe a slight vibration.
Adding a impeller kit, rubber flaps to the impeller blade will help, however this will not correct a loose belt problem, even making it worse.
post #5 of 18 Old 12-04-2019, 07:43 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
Blown auger shear pin or bolt on one of the augers?
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #6 of 18 Old 12-04-2019, 08:44 PM
2badknees's Avatar
Likes (Given): 23
Likes (Received): 13
Jeff, another possibility, but not a probability, could be a too low engine RPM at full throttle. Inductive tachometers are available online for $20. I have one and feel it's china junk, but the important thing is that it gets the job done.
Everything operated fairly well until I started working on it
2badknees is online now
post #7 of 18 Old 12-04-2019, 08:54 PM
Thanks (Given): 96
Likes (Given): 75
Get a Vibrameter for $25. Very accurate.
post #8 of 18 Old 12-05-2019, 12:11 AM Thread Starter
Thank you all for the suggestions! I ordered a an inductive tachometer but was not able to find a vibrameter anywhere for under$75.
I wont have time to pull off the cover and try engaging the auger belt until Friday afternoon or evening so I will get back to ya’ll.
Again, thank you all for the suggestions here. Much appreciated!
post #9 of 18 Old 12-05-2019, 12:29 AM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
. . . was not able to find a vibrameter anywhere for under$75.
Maybe a sirometer is what you are looking for
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #10 of 18 Old 12-05-2019, 07:52 AM
Thanks (Given): 96
Likes (Given): 75
https://www.amazon.com/Briggs-Stratt.../dp/B0044AV5VK
Yes, that was it. Works great. I compared it to an electronic one.
