826 drive axle - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-29-2019, 01:11 PM Thread Starter
826 drive axle
I bought this 826 and it is in pretty good shape. I noticed the diff is locked in all the time. I took the wing nut off of the left wheel and tried to remove the slip clutch but it was frozen. Finally removed it and the woodruff key buy it still doesn't slip. It appears by the manual that the axle should slide off of the axel shaft. I have put a slide hammer on it and gently pulled on it but it is not moving. Before I break something I thought I would seek some advice.
Thanks in advance. Jeff
Jeff Wilson is offline
post #2 of 5 Old 12-29-2019, 01:41 PM
Thanks (Received): 17
Likes (Given): 22
Likes (Received): 46
We need more numbers than 826 please.
strtch5881 is offline
post #3 of 5 Old 12-29-2019, 04:21 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
An 826 is an 826.. they were pretty much the same from 1980-1989 when they ceased production.
GoBlowSnow is offline
post #4 of 5 Old 12-29-2019, 04:30 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
Looks like there is a roll pin that needs to be driven out first.
dbert is online now
post #5 of 5 Old 12-30-2019, 05:49 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
The John Deere, JDs were different in that their model numbers you use to look them up were 1032, 826, ....
I think there is one or two other manufacturers that do that too.
