Choke knob - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-17-2020, 06:18 PM Thread Starter
Choke knob
I have a John Deere model 928E blower. I am needing to replace the carburetor. But I can not get the choke knob off. I have tried pulling with a channel lock and tried prying up with screwdriver. But I do not want to break the plastic shaft going to the carburetor choke. Any ideas on how I can get the choke knob loose?
jamess2345 is offline
post #2 of 5 Old 01-17-2020, 06:29 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 475
Likes (Received): 834
Welcome to the forum! Pictures of the engine and that area would help. If it's a typical Tecumseh engine, then the same setup may have been used on lots of machines, and you may get more feedback. But you mentioned a plastic shaft for the choke, so it may be different than what I'm used to working on.
On my Tecumsehs, the red plastic choke knob pulls off from the metal shaft.
post #3 of 5 Old 01-17-2020, 06:35 PM
Likes (Received): 22
Look at the bottom of the knob. Often there is a small slot cut into the knob with a small piece of metal in there. Take a small flathead screwdriver and push in on the metal. Knob should pop right off.
BlowerMods1 is offline
post #4 of 5 Old 01-17-2020, 06:47 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
The plastic shafts carb pull from the top, is this yours? If it pulls from the side, it has a metal shaft. I'd get a carpenter's nail puller bar, a smaller version of a crowbar, and use that, maybe with a piece of wood under it. What about the claw on a hammer? What about using a heat gun? Drilling a hole down the middle to the shaft top and then using penetrant?
JLawrence08648 is offline
post #5 of 5 Old 01-17-2020, 06:55 PM
Thanks (Received): 23
Likes (Given): 41
Likes (Received): 47
penetrating oil from the backside works good then pry from the back with a screwdriver, worst case use a large pair of channellocks and pull it straight off from the front, the knobs are only a few bucks
arienskids is online now
