1032D gear adjustment - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-23-2020, 08:30 PM Thread Starter
Hello Friends,
I have a 1032D that I bought around 2000. It has been a good machine until I hit a garden hose laying in the yard under the snow. Now it does not want to go in reverse and I have only 1,2 and 3 forward gears. Can anybody help? Thank you kindly!
94fuelie is offline
post #2 of 5 Old 01-24-2020, 04:11 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 459
Originally Posted by 94fuelie View Post
Hello Friends,
Start a new post and post pictures of the back bottom showing the linkage. The D means it's an Ariens made machine for John Deere.
post #3 of 5 Old 01-24-2020, 06:15 PM
Thanks (Given): 585
Thanks (Received): 764
Likes (Given): 4334
Likes (Received): 1727
Rather than hijack the other thread now you have your own
Have you tipped it up and pulled off the transmission cover to see what's going on inside ? That one has a round shaft the friction wheel assembly slides on. Might be the shaft needs a little bit of lubrication to allow the friction disc to slide freely and then adjust it.
https://partscatalog.deere.com/jdrc/.../pgId/17413402
post #4 of 5 Old 01-25-2020, 12:28 AM Thread Starter
Ok. I will see about getting som pics. Thank you!
94fuelie is offline
post #5 of 5 Old 01-25-2020, 12:30 AM Thread Starter
Sorry. I did not see the other thread. I just got registered. Thank you!
94fuelie is offline
