1032 D Drive broken - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-28-2020, 02:52 PM Thread Starter
1032 D Drive broken
My 1032 D would not go forward or reverse . I spoke with the dealer and they recommended changing the drive wheel as that is what usually wears out . After changing the drive wheel I still had the same issue. I found that the lever that engages the drive plate had a broken weld. I removed the part and had it welded and the machine is as good as new.
Sailcnc is offline
post #2 of 7 Old 01-28-2020, 03:34 PM Thread Starter
Here are some photos of the broken part
Sailcnc is offline
Post Thanks / Like - 2 Thanks, 3 Likes, 0 Dislikes
Thanks Eyeboltman, Kiss4aFrog thanked for this post
Likes Eyeboltman, notabiker, Grunt liked this post
post #3 of 7 Old 01-28-2020, 04:07 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
Nice looking repair.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #4 of 7 Old 01-31-2020, 09:58 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
I have the Ariens version of that machine..... Same part broke the weld.....in the same spot. Makes sense, since they are the same machines!!!! I had the same results. Good work finding that one!!
GLuck, Jay
JayzAuto1 is offline
post #5 of 7 Old 01-31-2020, 05:13 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Welcome to the SBF from Gettysburg!
2019 Ariens Compact 24...
penna stogey is offline
post #6 of 7 Old 03-04-2020, 12:35 AM
Thanks (Received): 26
Likes (Given): 113
Likes (Received): 67
I had the metal (was aluminum on my 97 JD 1032D) break one of three ears off. Thing still moved but that holds the shaft straight. Found a used ariens one that was solid steel on ebay for something like $50 and it came with the shaft and round plate the friction disc contacts.
I wish it was just the arm like yours that broke as that would have been much easier. Though mine is much stronger now.
notabiker is online now
post #7 of 7 Old 03-04-2020, 03:30 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 745
Likes (Received): 266
welcome to snow blowers Sailcnc hang around and enjoy
87powershiftx2 is offline
