TRX24 Primer Not Working - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-14-2014, 10:59 PM Thread Starter
Exclamation TRX24 Primer Not Working
Just got a John Deere TRX24 and the primer does not work. It's been colder than an x-wives shoulder and I finally got it started and running good with starter fluid. I know it has a Tecumseh 5 hp engine but have not been successful in finding a replacement primer.
Any help will be greatly appreciated.
The Grand Pooh-Bah is offline
post #2 of 7 Old 11-14-2014, 11:10 PM
Thanks (Given): 173
Likes (Given): 460
Likes (Received): 1038
Probably not the primer itself. Check every inch of hose from primer bulb to carb. I've seen more than one of them collapse or just rot. And try your best to not use starting fluid.
And welcome to the forum.
post #3 of 7 Old 11-15-2014, 04:54 AM
Yea, starting fluid is bad for an engine. As for the primer, make sure the hose is connected to the primer and the carb. Also make sure there are no holes in it. Sometimes the nipples can break off the back of the primer bulb too.
post #4 of 7 Old 11-15-2014, 08:04 AM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
The Murray I'm working on was that way. The primer hose was rotted off and hanging in mid air at the carb. There was just enough of it left on the carb to cover the barb but I'm guessing age and vibration tear it at that point. I seem to find it broken off at the carb a common problem on the older stuff.
post #5 of 7 Old 11-15-2014, 10:15 AM Thread Starter
Thanks, I will check that when it warms up a bit. 9F right now. Still waiting for our first snow.
post #6 of 7 Old 11-16-2014, 03:23 AM
The primer hose rot will be the most common issue. I even had it on a 7 year old Ariens this year.
Ryan is offline
post #7 of 7 Old 11-16-2014, 11:28 AM
Thanks (Given): 590
Likes (Given): 4367
Where are my manners, welcome to the forum Grand Pooh-Bah
