TRS22 no power runs poor - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-31-2015, 08:00 PM Thread Starter
Today I wasn't"gifted" a JD trs 22 in decent shape but owner was fed up with issues. I took carb apart and cleaned, it ran but had no power. Took compression check and found 35psi....
Pulled head thinking head gasket and found the exhaust value not seating.... Cleaned and filed stem until it closed as tight as the intake...100psi and now throws snow. I just read that this same issue was suggested by a member in another post ....I take it this is a common issue with the HSSK40?
A little research tells me this is a "Murray" built JD and does not have a good reputation and parts are no longer available....bummer.
I have not figured out the governor set up, as I think former owner tinkered with it to compensation for lack of power. And suggestions on that?
Jdufour88 is offline
post #2 of 4 Old 01-31-2015, 08:05 PM
Governor and throttle linkages:
https://www.youtube.com/user/donyboy...cumseh+linkage
post #3 of 4 Old 01-31-2015, 08:55 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Good job finding/fixing the compression issue!!!! Awesome job actually!!!!
It sounds like you already have seen it...but in case you haven't, here's the L-head service manual: Link.
from page 31:
With the engine stopped, loosen the screw holding the
governor clamp on the governor lever. Rotate the clamp
in a direction that will force the throttle shaft open and
allow the governor follower arm to rest on the governor
spool. Push the governor lever connected to the throttle
to the wide open throttle position. Hold the lever and
clamp in this position while tightening the screw (diag.
7).
('87 Toro 38150 826)
post #4 of 4 Old 02-01-2015, 06:51 AM Thread Starter
Thanks for your help on the governor linkage.....I'll give it a go today.
