decode serial number - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-03-2015, 04:16 PM Thread Starter
Thanks (Given): 80
Thanks (Received): 17
Likes (Received): 15
I found a place to do it for ariens but I'm looking for year of manufacturer and some other info. What can you get from this #
m828dx172682
96 Mustang - Race car
2005 Mustang - Daily Driver
15 Grand Cherokee Altitude - Mall Crawler
2007 Anderson Open Deck 19ft Trailer
1998 828D John Deere
1996 828D John Deere
2015 D110 John deere
ST724 Ariens not sure of year
1978 Ariens 924000
1964 10ML60D
Duff Daddy is offline
post #2 of 9 Old 02-03-2015, 05:44 PM
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Where did that number come from? Ariens serial # or off the engine?
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
Thanks Duff Daddy thanked for this post
post #3 of 9 Old 02-03-2015, 05:49 PM Thread Starter
Thanks (Given): 80
It was on the case
1978 Ariens 924000
1964 10ML60D
post #4 of 9 Old 02-03-2015, 06:27 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 930
No one on this forum has a Deere decoder key, that I have ever seen..
but I googled it!
and found this:
How to Read a John Deere VIN | Home Guides | SF Gate
your number: M0828DX172682
Identify the first two letters or numbers in a 13-symbol VIN or the first three letters or numbers in a 17-symbol VIN; this is the factory code (also known as engine manufacturer)
M0
Google doesnt seem to know who M0 is, but its probably just the code for the engine manufacturer, not where the snowblower itself was made.
Identify the next four letters and numbers after the factory code, which will be positions three to six in a 13-symbol VIN, or positions four to seven in a 17-symbol VIN. This is the model number. For instance, in the John Deere VIN CD6068G123456, 6068 is the model number.
828D - That makes sense as a model number..Is it 8hp with a 28" bucket?
Identify the letter in position seven in a 13-symbol VIN. This is the emissions level designation.
X
Identify the last six letters and numbers in a 13-symbol VIN or the last five digits in a 17-symbol VIN. This is the serial number and is unique to your specific tractor. The serial number can be used to track and identify individual John Deere tractors.
172682
That site refers to tractors, not snowblowers..but there are 13 digits in your snowblower number, so it seems likely the same conventions apply, although I dont know that for certain..but it seems to make sense..
if you snowblower is in fact 8hp and 28" bucket, then we can be sure thats the right decoder ring!
post #5 of 9 Old 02-03-2015, 06:30 PM
Thanks (Given): 72
Likes (Given): 182
This is probably an Ariens!
please post some photos, and the engine data tag numbers, if you can..
post #6 of 9 Old 02-03-2015, 06:31 PM Thread Starter
Thanks (Given): 80
scotty you the man. THanks it is an 828d ... figured that would pop up but didnt know like ariens does if it tells you year with the model/serial number.
1978 Ariens 924000
1964 10ML60D
post #7 of 9 Old 02-03-2015, 06:56 PM
Thanks (Given): 24
Likes (Given): 15
Oh, its the JD serial number. I know I was looking up one for someone a few months back on here and ended up stopping at the JD dealer around the corner from me for accurate info. I can do the same for you if you need...let me know...
EDIT- found the old thread: https://www.snowblowerforum.com/forum...nufacture.html
JD uses the serial number to date the machines...
Ray
1962 Ariens 10ML60
1979 Toro 524
post #8 of 9 Old 02-03-2015, 08:46 PM
Thanks (Given): 72
Likes (Given): 182
I believe any Deere snowblower with a "D" in the model name was made by Ariens..
They were made 1991 to 2001.
Post a few photos, that will clinch it for Ariens, and post all Tecumseh numbers from the engine data tag,
that will tell the exact model year..
Scroll down past Cub Cadet and Bolens for info on the Ariens/Deeres
http://gold.mylargescale.com/scottyc...html#question3
post #9 of 9 Old 02-04-2015, 09:07 AM Thread Starter
Thanks (Given): 80
Scott,
It is an Ariens design, I can tell by the bucket.
1978 Ariens 924000
1964 10ML60D
