JD726 axle pin - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-22-2015, 12:41 AM Thread Starter
JD726 axle pin
Having an issue with the left axle pin sheering off. Replaced with a spring pins. It came out. Replaced with cotter pin twice sheered off. Any suggestions?
wsmcdade1 is offline
post #2 of 4 Old 02-22-2015, 09:28 AM
welcome to sbf wsmcdade1 it would be more helpful if you could post model and serial no. what is it doing before it shears the pin off. I cant help much but I will give you a bump.
BB Cub is offline
post #3 of 4 Old 02-22-2015, 09:54 AM
Thanks (Given): 30
Thanks (Received): 40
Should be able to get a new axle pin just about any good size hardware store that sells blowers, or the big box might even have them. They are generic usually , just a pin with a ring. Get the right size to fill the hole, a smaller, looser pin will shear.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #4 of 4 Old 02-22-2015, 10:57 PM Thread Starter
type# W2121 serial#002427M, Well while i was installing a new pin today I believe I discovered the issue. It appears that the differential is not functioning properly. When attempting to turn both wheels are locked.
