Old John Deere snowblower, help finding parts - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 11-24-2015, 06:04 PM Thread Starter
I just picked up a John Deere snowblower from
Someone for free. The engine does not work (owner said he thinks a cylinder dropped on it) and I am looking to rebuild it.
What I know it's from 1978-1980. And the serial number is: P826J 126650 M
I have attached pictures. What exact engine is in it? Where can I find a rebuild kit? I have attached pictures of the unit as well.
ID:	64257   Click image for larger version
ID:	64265   Click image for larger version
ID:	64273   Click image for larger version
Jbpiv is offline
post #2 of 19 Old 11-24-2015, 06:12 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
If you remove the 2 bolts for the electric starter connector on top of the flywheel cover, you should see the engine type stamped on it.
looks like an HM80 variant.
I don't know where you are located but you can usually find a running HM80 for $100 to $150 on craigslist.
You'd be looking at ~$100 for the rebuild parts alone.
db130 is online now
post #3 of 19 Old 11-24-2015, 06:16 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 663
are you wanting to rebuild for the enjoyment, or because you need a working machine ? there should be a tag on the engine itself for the "enjoyment" work, and a repower would be a better option for the " working machine". ( if its a dual shaft engine, things kinda change)
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 19 Old 11-24-2015, 06:37 PM
Likes (Received): 303
Quick and easy way to check your cylinder is pull the plug and flash a light in there as someone pulls the rope. You should see the piston move up and down. If it's a thrown rod, you can usually feel it just by pulling the rope (if it moves, it may not) there won't be compression at all. Rebuilding depends on the internal damage. You can remove the electric starter and see if there's a hole in the block behind it. I refurbed an 826 a little newer than yours. They are very easy to work on and built very well.
post #5 of 19 Old 11-24-2015, 07:58 PM Thread Starter
Going to try to take it apart tonight to get a feel for what's going on. Tried pulling the rope, does not even budge.
If I were to go rebuild route, how do I determine what exact engine I have to get parts for it?
What options do I have if I swap it out?
Here's the owners book I got but this hasn't helped me much on my google searches
Jbpiv is offline
post #6 of 19 Old 11-24-2015, 08:29 PM
Look along this line for a stamped alpha numeric series. (HM80xxxxxx)
That will ID your engine for which Tecumseh parts you may need. Easy enough to pull the bolts on the electric starter motor under the gas tank and look behind it. If you can see into the engine, you don't need to look for parts If no hole and the recoil is stuck, it may just be seized. See if there's any oil in it. If it's only seized and no hole behind the starter you MIGHT be able to salvage it. At that age the head bolts tend to stay with the block and repowering may be easier and cheaper. Break off one head bolt and one exhaust bolt and you've got a bad start to rebuilding.
post #7 of 19 Old 11-24-2015, 08:42 PM
The code written in your owners manual 9264D is the tail end of the engine ID. It tells you it was made in decade ending in "9" likely 1979 by appearance and model of blower on the 264th day on line "D" of the factory. Friday, September 21, 1979. You need all the letters and numbers before that part of the serial number to look up correct parts.
post #8 of 19 Old 11-24-2015, 09:49 PM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
Welcome to the forum Jbpiv
On some engines that stamped engine number is under the electric start button assembly and you need to remove the two screws to tilt it out of the way.
This site is great for finding part numbers and seeing drawings then use the part number on google, amazon and Ebay to get the best deal.
John Deere - Parts Catalog
post #9 of 19 Old 11-24-2015, 10:01 PM Thread Starter
So I think I got the serial... The plate was pretty rusted right where the serial was engraved. But from the best I can tell I have HM805156013F. SER 9264D
I am only unsure on the following #5 &6-> HM80[5]15[6]013F
Picture below for how bad it looks.
Also, took off the starter and I got a nice crack... Picture below as well
ID:	64313   Click image for larger version
Jbpiv is offline
post #10 of 19 Old 11-24-2015, 11:24 PM
Thanks (Given): 16
Likes (Given): 241
Like I said, start looking for a replacement hm80
db130 is online now
