JD1032 - Wheel is crooked - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-16-2015, 01:48 PM Thread Starter
Likes (Received): 16
Hello:
Working on a JD 1032 and noticed that one wheel is crooked.
Don't know how it happened, got it second-hand.
The top of the wheel (at 12:00 o'clock) is tipped towards the center of the machine and not sitting straight vertically.
It's very noticeable- more than the picture shows.
Any idea what is causing this? Wheel bearing/bushing? Thanks in advance.
Ariens-777 is offline
post #2 of 14 Old 12-16-2015, 02:03 PM
Bent axle or bent wheel. If you take the wheel off, you can check the axle with a straight edge.
Alexsha is offline
post #3 of 14 Old 12-16-2015, 02:38 PM
Likes (Received): 303
Had a great idea if it was a JD OEM, but from looking, it's a Murray design. Hopefully it's a bombed out axle bushing (real simple to replace). A better look would be from the (belly pan removed) bottom. Left alone, and to grind the axle, can make some strange angles without grease.
After looking further, that machine has extreme rust in all the wrong places. Under water? Anyway check the belly pan with a pic will USUALLY find the culprit.
Try picking the machine up and hand rotating the tires, does it go from correct to obviously wrong as you do so? Could have been just dropped off a truck or trailer.
post #4 of 14 Old 12-16-2015, 03:11 PM Thread Starter
Found the problem. Thinking to swap the whole housing out.
Anyone know which Ariens model housing will swap with this JD1032D? There's an Ariens ST824 for parts locally. Thanks.
post #5 of 14 Old 12-17-2015, 09:25 AM
I stand corrected, that flimsy chute crank design screams Murray, but the tractor body metal and that wheel hub appear to be Ariens. With the "D" thrown in the mix for a model number, that changes things. Don't know for sure, just guessing the 824 parts machine will be a 3 bolt wheel hub? If you can get that hub off the axle, couldn't you just knock it back straight and weld it? Is that the differential side of the axle? Worth trying to save as those parts are expensive, especially if they work.
Appears to be like the hubs on Ariens models 924050,924051,924073
Ariens part numbers :
Ariens 02440900
Ariens 02475800
Likes Grunt liked this post
post #6 of 14 Old 12-17-2015, 09:35 AM
Thanks (Given): 590
Likes (Given): 4367
Likes (Received): 1742
to the forum 777
Have you tried looking it up on the JD parts web site for a Part number ??
Once you have that you can cross reference it to see if there are other manufacturers (Ariens, Toro, ...) that use it too.
Maybe better price.
John Deere - Parts Catalog
post #7 of 14 Old 12-17-2015, 11:56 AM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Looks similar to a 4-lug hub from an Ariens 924000 series. Is it solid axle or does it have a differential?
db130 is offline
post #8 of 14 Old 12-17-2015, 12:31 PM
Thanks (Given): 590
Likes (Given): 4367
If you have a 1032D it might be part # 27 in the diagram P/N AM120299 and if so it's likely going to be over a hundred new. You could also weld it.
This is what I found:
post #9 of 14 Old 12-17-2015, 12:49 PM Thread Starter
Thanks for the replies. I'm headed across town to look at an Ariens
ST824 parts machine. I think the axles are the same. If not, I will
have it welded.
I need #39 in the diagram, about $140 online.
Will update later. Thanks again.
post #10 of 14 Old 12-17-2015, 02:41 PM
Thanks (Given): 590
Likes (Given): 4367
#27 is the Left shaft.
The pictures you posted show the left wheel. I'm confused.
