1032 Vibrates - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-07-2016, 03:45 PM Thread Starter
1032 Vibrates
This thing throws the snow but it beats me to death. Is this normal the stock 10HP Tecumseh engine is loud, and vibrates everything to death? My hands and arms are tired after wrestling this bad boy. Also, it seems to vibrate parts loose quite often, and I always seem to be re tightening bolts or other parts falling off after a session of blowing snow. Kinda funny, but I feel like I have run a jackhammer for hours after running this darn 1032. Your thoughts?
Glockem45 is offline
post #2 of 16 Old 02-07-2016, 04:42 PM
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 109
Try thread lock on those nuisance bolts. Also when I restored my 8/32 I added a poly/ rubber bushing under the engine base. There isn't much room on the bolt so it can't be to thick. Only about 5mm and the lock washer had to stay off. I used high strength thread lock on the bolts. It helped with the vibrations being transfered to your hands and arm. Still could feel it but not as bad. Also seemed to quite the machine down just a bit. As for wrestling the 32 inch. It's just the nature of the beast.
74 Ariens 832
8? FMC Bolens 824
02 White 4x4 Snow Boss
90 Lawn Boy ST320
88 Honda 300FW w/plow
guilateen02 is offline
post #3 of 16 Old 02-07-2016, 05:48 PM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
shouldn't be vibrating like that. Wonder if you have something out of balance..
GoBlowSnow is offline
post #4 of 16 Old 02-07-2016, 06:46 PM
Thanks (Given): 559
Thanks (Received): 733
Likes (Given): 4164
Likes (Received): 1602
I'd pull the belt cover and see what the drive pulley and belt look like.
Is it vibrating all the time ??
post #5 of 16 Old 02-07-2016, 07:28 PM
its more then likely the engine, maybe the impeller bearing
post #6 of 16 Old 02-07-2016, 10:53 PM
Thanks (Received): 112
Likes (Received): 296
+1 on the thread locker, or replace the nuts that come loose with Nyloc nuts. Nothing worse than having a chute fall of in mid storm. Have you noticed it the engine mounting bolts are loose? That could add quite a bit of vibration.
For a test to help pin down where the vibration is coming form, try removing both the auger and drive belt, and then run the engine and see how bad it is. If it's still bad, the engine is the cause, check for missing fins on the fly wheel if you have them.
If the engine itself is OK, then add back the impeller belt and try it with just that and the engine. If you pick up the vibrations when the impeller is running, you know where to look.
You could do the same test with the traction belt only as well, although there's less stuff there to go wrong.
Work fascinates me.
skutflut is offline
post #7 of 16 Old 02-08-2016, 09:41 AM
Thanks (Received): 19
Likes (Given): 23
Likes (Received): 62
I have a 1032 and mine runs fine with no vibrations other than the norm.
I would take a look at the belts, pulleys, Bearings. Doe's it vibrate all the
time even when the auger isn't spinning. If someone had the flywheel off
may be there are some missing flywheel fins. Sounds like you have something
terribly out of balance or bent.
Lee
John Deere TRS32
Craftsman 1032 Drift Breaker
John Deere 1032
Bolens 1032
John Deere 1032 Project
lee h is offline
post #8 of 16 Old 02-08-2016, 09:45 AM
Thanks (Received): 33
Likes (Received): 54
LOL. This happened to me on my 621. One year, I lost a bolt holding the handlebar. Ordered parts and replaced both side with Nylocs.
This year, one on the chute went awol, and suddenly it was flopping limp.
Just got the proper bolt in last week. Replaced all chute nuts with Nylocs.
When it get's warmer, I plan to eyeball to see if there's anything I might want to remove and put some Loctite on.
mobiledynamics is offline
post #9 of 16 Old 02-08-2016, 10:03 AM
What really sucks, is when a bolt or something falls of, you dont notice right away, and you suck it up in the next pass and it flys away with the snow, never to be seen again, OR, it goes through your living room picture window
Work fascinates me.
skutflut is offline
post #10 of 16 Old 02-08-2016, 01:20 PM
Have you ever found a bolt that has rattled loose ;-)
If only I had that luck.
The lever on the fuel knob on my 621 came off. I didn't even know it.
Wifey found it.....luckily both the know and screw on it.
Worst is order a $bolt and then pay $$ ontop to get it shipped...
