Drive Chain Part Number - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 03-13-2016, 08:56 PM Thread Starter
Thanks (Given): 66
Thanks (Received): 19
Likes (Given): 139
Likes (Received): 27
As some of ya know, I have a JD Model W2121, Serial #: 014417M that needs a drive chain. The sprocket is closest to the left wheel, and connected to the transmission. I think the part number may be 579851MA, or a 420 x 19 chain.
The actual chain stretched out is longer than 19 inches...it close to 23 (if I remember correctly).
Anyway, can anyone help me make sure I order the correct replacement chain. It interesting....I don't even get a response when I put my model number into the John Deere site for parts, etc.
Thanks all.
gsnod is online now
post #2 of 10 Old 03-14-2016, 10:41 AM
Likes (Received): 280
Can you identify what chain # it is? Sometimes they are stamped on the sides..... you can buy most chains in bulk length at farm stores and just make your own.
post #3 of 10 Old 03-14-2016, 11:33 AM
404
Thanks (Given): 45
Likes (Given): 53
Likes (Received): 10
Is the number of links in this pic the same as your chain?
Chain, Roller #420X19.00 [579851MA] for Lawn Equipment | eReplacement Parts
404 is offline
post #4 of 10 Old 03-14-2016, 06:56 PM Thread Starter
Thanks (Given): 66
Likes (Given): 139
Thanks Bad69cat and 404. I think it looks like the picture in the link that 404 sent. BUT, is there any connection between the number of links and the numbers -- such as 420 x 19?
In the meantime, I'll go look at the chain to see if I can see any numbers stamped in the side. Probably best to go to TSC this weekend with the chain and match it up...
gsnod is online now
post #5 of 10 Old 03-14-2016, 11:11 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
I come up with TYPE 41, 50 LINKS.
Tru-Pitch Roller Chain, Chain Size 41 - For Life Out Here
post #6 of 10 Old 03-15-2016, 12:35 PM
404
Thanks (Given): 45
Likes (Given): 53
See pic for 420 chain dimensions. The length may match 19 inches when the chain is brand spanking new. 10 minutes after it is put on it will be a bit longer. Counting the links is the only sure way.
404 is offline
post #7 of 10 Old 03-15-2016, 10:35 PM Thread Starter
Thanks (Given): 66
Likes (Given): 139
Took a look tonight and did see stamped Hitachi 41 and a total of 50 links. I've never bought chain by the length before, so this is a new experience. I see two options:
1. Buy what Kiss4aFrog suggest below, as I'm guessing that is what I need, OR
2. Go to TSC and buy a length and make my own. I've replaced links, and that is easy. I assume TSC will have the link connectors right there...
Suggestions?
gsnod is online now
post #8 of 10 Old 03-16-2016, 11:18 AM
yep - they have the connector links. Easy peasy....
post #9 of 10 Old 03-17-2016, 12:27 PM
Thanks (Given): 588
Likes (Given): 4353
That link is to Tractor Supply and it is bulk chain. I got the type 41 and 50 link from JD just wasn't absolutely positive it was correct for your exact machine.
Looks like it is
I had three chains on a Drift Breaker I needed to replace so I bought the 10' bulk at Fleet Farm and a chain breaker. Still less than the three and shipping and now I have the tool. I don't do chains very often or I'd spend another $10 and get the better tool.
Tru-Pitch Chain Breaker, PE2560 - For Life Out Here
Tru-Pitch Chain Breaker, PE60100 - For Life Out Here
post #10 of 10 Old 03-19-2016, 04:23 PM Thread Starter
Thanks (Given): 66
Likes (Given): 139
Thanks Kiss4aFrog and all -- Yep, went down to Boston lawnmower, and they cut me a new chain type 41 for $10. Can't beat that, as I don't work too often with chains. So, I'll put the chain on and an engine, and maybe use this blower on the couple of inches we're supposed to get Sunday night/Monday morning.
Looks like it is
gsnod is online now
