Use with both wheels locked or one freewheeling? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-03-2016, 04:21 PM Thread Starter
Dickbelle's Avatar
Thanks (Given): 20
Likes (Given): 9
This may seem like a dumb question, but since I don't have and can't find an operator manual, here goes. On the JD TRS24, and I'm sure many other models, there is the option of having both wheels locked to the axle, or to have one freewheeling. The second option certainly makes it easy to move the machine around in the garage, but is it used for actual snow blowing, such as in a light snow or if traction isn't bad, or do both wheels need to be locked to the axle?
1993 John Deere TRS24
Dickbelle is offline
post #2 of 8 Old 11-03-2016, 04:35 PM
Thanks (Received): 173
Likes (Given): 413
Likes (Received): 661
i personally wouldnt consider trying to blow snow with only one wheel driving the machine. i would rather manhandle it to turn it around , than fight it to keep it going straight, or have to push it to keep going forward. jmo
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Thanks Dickbelle thanked for this post
post #3 of 8 Old 11-03-2016, 05:20 PM Thread Starter
Dickbelle's Avatar
Thanks (Given): 20
Likes (Given): 9
Makes total sense. I guess I will "learn by doing". Thanks!
post #4 of 8 Old 11-03-2016, 06:39 PM
Thanks (Given): 102
Likes (Given): 273
You'll want both wheels locked. It's nothing to spin these machines around on a slick surface.
uberT is online now
post #5 of 8 Old 11-04-2016, 06:54 AM
Thanks (Given): 585
Thanks (Received): 761
Likes (Given): 4322
Likes (Received): 1721
On the ones that have that option I keep both locked most of the time. It's never been that hard for me to swing it around. That said as I'm getting older I do notice the easier turning effort a big machine with a differential has.
When not blowing snow I'd unlock one as it's much easier to move one around on a dry surface with one unlocked.
post #6 of 8 Old 11-04-2016, 07:00 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
My best answer would be "it depends on the circumstances".
I have a machine with the same feature, and 90% of the time when I'm actually removing snow, I keep the wheels locked. As others have said it helps traction a lot, and helps keep the machine going straight... assuming that's what you want.
Sometimes when removing snow in a tight area where a lot of maneuvering is required I'll unlock the wheels and I definitely unlock it when I'm moving the machine in or out of the garage.
ELaw is offline
post #7 of 8 Old 11-08-2016, 12:17 PM Thread Starter
Dickbelle's Avatar
Thanks (Given): 20
Likes (Given): 9
Thanks, guys for the insight. All that's left now is to wait for the snow!
post #8 of 8 Old 11-26-2016, 06:03 PM
Thanks (Given): 9
Likes (Given): 26
Likes (Received): 14
Lock both of em up. 'Tis much better..............
1994 John Deere TRS26
1992 TORO 521
DaHen is offline
Likes Dickbelle liked this post
