lawnboy insight - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 15 Old 03-05-2014, 01:51 AM
sj701's Avatar
Thanks (Given): 9
Thanks (Received): 19
Likes (Received): 26
Originally Posted by r2d View Post
Ya and they had different hp ratings. Snow commander was 7hp
2450 had governor set at 3800rpm
3650 had governor set at 4000rpm
commander had governor set at 4000rpm and different piston and cylinder.
Snowblowers in the shed. All made in the good ol USA.
Bobcat 28" 2 stage 8hp Briggs
Bobcat 24" 2 stage 7hp Briggs
Bobcat 20" 2 stage repowered with Tecumseh OHH50
Lawnboy Snowboy
Lawnboy Snowboy self propelled
Toro 6000 Rtek Powered
Toro CCR2000 Suzuki Powered
Toro CCR2500 Tecumseh Powered
Toro CCR3650 boxy one, Rtek Powered
sj701 is offline
post #12 of 15 Old 03-05-2014, 03:54 AM Thread Starter
r2d
r2d's Avatar
Thank you for that info! I was wondering why the different ratings. does the piston have a dome on it? For the snow commander of course.
Toro ccr2000, 3000(2) and 3650(2)
Oh and a couple s-200's and borrowing an Ariens 724
Looking for suggestions on professional two stage that can handle big snow. Dont need a super wide cut.
r2d is offline
post #13 of 15 Old 12-07-2014, 02:25 AM
I bought a Toro 3650 new in 2005, it's been able to handle any amount of snow with ease. And i just found a 2006 Lawn Boy Insight 1000 (model 33006). They are the same except for the chute control and the handles are padded and adjustable on the LB. Also the recoil on the LB is the better D shape. And the servicing is easier on the LB as the chute crank is in the way on the Toro 3650. Both are great machines and will give a two stage blower a run for the money. These machines can throw snow 35 feet and have cruised through drifts higher the the chute, and will clean snow down to bare pavement.
33006 is offline
post #14 of 15 Old 01-12-2015, 01:39 PM
I thought I would post some pictures of my recently found 2006 Lawn Boy Model 33006/ Insight 1000E comparing it to my 2005 Toro Model 38518/ CCR3650.
ID:	35361   Click image for larger version
ID:	35369   Click image for larger version
ID:	35377   Click image for larger version
33006 is offline
post #15 of 15 Old 02-10-2015, 01:34 AM
Likes (Received): 10
I have an insight. Only issue is the plastic carburetor.But they make an metal replacement.But its pricey at about $100 But it throws snow great
pdesjr is offline
