lawnboy insight model 34001 sn280000 - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 07-28-2014, 02:55 PM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Thanks (Received): 59
Likes (Given): 1100
Likes (Received): 253
Just picked up a non-running lawn boy single stage 4 stroker. If i get her going the mtd is out the door.
gibbs296 is online now
post #2 of 16 Old 07-28-2014, 06:58 PM
Thanks (Given): 219
Thanks (Received): 294
Likes (Given): 1762
Likes (Received): 620
looks like a toro 421 /621. early 421 single stage machines seem to have carb problems
post #3 of 16 Old 07-28-2014, 10:19 PM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Likes (Given): 1100
A little brake clean in the carb opening and she fired right up. Sounds like you are correct. Any thoughts as to the extent of their issues?
post #4 of 16 Old 07-29-2014, 08:44 AM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Just a tip, try to avoid brake cleaner on your carb. It ruins all the little gaskets and seals, it's too harsh for carbs. Stick with carb cleaner.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
Thanks gibbs296 thanked for this post
post #5 of 16 Old 07-29-2014, 11:12 AM
Grunt's Avatar
Thanks (Given): 256
Thanks (Received): 306
Likes (Given): 3089
Likes (Received): 595
There was a recall affecting certain serial number 421's in 2011?? and are posted on line doing a Google search. Toro said that ethanol fuel was eating the aluminum in the carbs and causing the needle valve in the carb to stick open and leaking fuel. I have a 421 and never had any problems with carb leakage. As a precaution, I added an in-line fuel shut off, which is a good idea on ANY gas powered equipment. The 421 Toro's used Tecumseh LH195SP engines in them.
Your model is a 2008 and a parts breakdown can be found here. Just enter your model number (34001).
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
post #6 of 16 Old 07-29-2014, 02:01 PM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Likes (Given): 1100
Thanks Grunt, I'm pretty excited about the Lawn Boy to be honest. It's much more solid than the mtd single i have and has the look of a machine that can hold its own in a pretty deep snow.
post #7 of 16 Old 07-29-2014, 06:30 PM
Thanks (Received): 363
Likes (Received): 1296
well now you can ROCK THE HOUSE with the lawn boy. and dump the mtd. but stay away from the brake kleen for the carb end of it.
post #8 of 16 Old 07-30-2014, 03:48 AM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Likes (Given): 1100
Dumped out the old nasty gas, drained the carb, added fresh fuel with a little sea foam and she fired right up. Happy days ahead!!
post #9 of 16 Old 07-30-2014, 03:55 AM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Likes (Given): 1100
after a little cleanup...
post #10 of 16 Old 07-30-2014, 04:18 PM Thread Starter
gibbs296's Avatar
Thanks (Given): 147
Likes (Given): 1100
One of the wheels is cracked down the middle and i have read others saying the wheels on these singles aren't the best. I see menards has a large selection of wheels, anyone had any luck with these fitting a lawnboy\toro? Also my starter handle is broken. Any decent low price substitutions? Thanks in advance.
