Lawn Boy 720E snowblower - Page 3 - Snowblower Forum : Snow Blower Forums
post #21 of 29 Old 01-07-2015, 07:53 PM Thread Starter
720E was delivered by FEDEX at 11.35am today. -2 below and I'm outside unpacking the snowblower, I must be nuts. Well it made the trip from New York OK. The boss isn't home so I brought it inside into the kitchen and started checking it over, removing the control panel, crank handle, top cowl. I pulled the spark plug and found it had the wrong NGK plug. Tested the electric starter, it operates ok. Installed a correct NGK plug gaped at .030 and when about cleaning the inside areas and the cowl and pnl.and then reassembled the parts. The scraper bar and rotor blades are ok, about 50-60% of original thicknesses. I will be using this some and will replace these and the belt after this winter. Next I pulled the left side cover and removed the belt, its also ok, no cracking or chunking. I cleaned the cover and the interior and reinstalled the belt, and checked the cable adjustment which was ok. Before reinstalling the cover I did a minor cosmetic repair, straightening the bottom edge and touching up the paint on the bottom edge. Then I noticed the left wheel axel was bent, so I removed the wheel and straightened the axel. Time to go outside and give it a workout on the snow drift crossing the driveway. I filled the gas tank and set the choke, primed twice and 1 pull. Yes it started on one pull, took the choke off and it settled down to a steady RPM. Attacked the drift, no problem 12+ inches high it just charged in and the governor kicked in and it got more power and never slowed down. It looks great and runs very good. Green machine #2 in the Green Team snow removal team.
33006 is offline
post #22 of 29 Old 01-07-2015, 08:30 PM
Thanks (Given): 223
Thanks (Received): 294
Likes (Given): 1832
Likes (Received): 637
happy days are here again, congrats
post #23 of 29 Old 01-08-2015, 09:41 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 115
Likes (Received): 143
Congrats! Well worth the wait. Sounds like a great machine. Enjoy!
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is online now
post #24 of 29 Old 01-09-2015, 01:13 PM Thread Starter
Thanks guys, I will try to get out in the garage later today for a couple of pictures of the Green Snow Removal Team.
33006 is offline
post #25 of 29 Old 01-12-2015, 12:38 PM Thread Starter
Originally Posted by Freezn View Post
Congrats. Great score on the 720E. Nothing like the thrill of the hunt for a sought after machine then closing the deal. Yes, please post pictures of the 720E when it arrives home. In fact, if it's not too much trouble I'd like to see the "family portrait" of the entire Green Machine Snow Removal Team.
OK, Here are pictures of the Green Machine Snow Removal Team resting comfortably waiting for the next snow. One of the pictures shows the handle of the 2006 Model 33006/Insight 1000E that is comparable to a 2006 Toro Model 38518/CCR 3650 except that the Lawn Boy has an adjustable and padded operator handle. The other is a 2002 Model 28226/720E that is like the old style Toro 3650.
Name:	SAM_0778 - Copy.jpg
ID:	35321   Click image for larger version
ID:	35329   Click image for larger version
ID:	35337   Click image for larger version
ID:	35345   Click image for larger version
33006 is offline
post #26 of 29 Old 01-12-2015, 06:49 PM
Thanks (Given): 223
Likes (Given): 1832
my second favorite shade of green, nice stable
post #27 of 29 Old 01-12-2015, 09:13 PM Thread Starter
Thank you, I now can play with (use) a Green machine in the summer and winter. Life is good.
ID:	35914   Click image for larger version
ID:	35922   Click image for larger version
ID:	35930   Click image for larger version
ID:	35938   Click image for larger version
33006 is offline
post #28 of 29 Old 01-13-2018, 08:51 PM
Since you have a 720e, can you please tell me what the gas to oil ratio is? I inherited 1 without a manual. Now I need to put gas & oil, but can't find how much I should be putting in. Thanks, Julie
Julie is offline
post #29 of 29 Old 01-13-2018, 09:22 PM
Its a 50:1 ratio, should be on the gas cap.
Currently waiting for snow...
2004 Yard Machines 8/24 For the big storms
2003 Toro Powerlite That waits in my trunk, should the need arise... shoveling... HA!... ya, don't think so.
2002 Toro 2450 Primary machine
1991/1992 Honda HS621 Backup for the 2450
TheFanMan is offline
