Lawnboy320E no start - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-12-2016, 08:40 PM Thread Starter
Hey all i have a 320e that cranks but wont start. It has a spark....smells of gas on the plug, so im wondering if its some how the carb. If so how do i go about getting access to the carb-looks like the top housing has to come off but how to do so. Help! tyvm in advance ....
mikelawnboysnowthrowe320E is offline
post #2 of 7 Old 01-12-2016, 11:48 PM
Likes (Received): 279
How fresh is the fuel? It might be flooded - try using less choke and no prime and see what happens. Have you drianed or cleaned it up at all? Check this out:
post #3 of 7 Old 01-13-2016, 10:04 AM Thread Starter
Hey bobcat, the fuel is new as is the sparkplug. I ended up having to dump as much of the old gas away as i could. I did also play with the choke in off position also. How would i access the carb on this machine.Do not know how to remove the top cover, or is there another way/?.Tryed looking on youtube fr a video, but got nothing.
post #4 of 7 Old 01-13-2016, 10:11 AM
Thanks (Given): 221
Thanks (Received): 294
Likes (Given): 1774
Likes (Received): 620
the back cover has to be removed to get to the carb mike
Likes mikelawnboysnowthrowe320E liked this post
post #5 of 7 Old 01-13-2016, 10:51 AM
Jackmels's Avatar
Thanks (Given): 126
Thanks (Received): 189
Likes (Given): 440
Likes (Received): 776
Everyone should have a can of starting fluid on hand. If your dead engine won't "pop" using this, you know it's an ignition problem. If it "pops" but wont run, it's a fuel problem.
Jackmels is online now
post #6 of 7 Old 01-13-2016, 11:44 AM
yeah - if it won't pop with ether you know you have no spark. If it pops but wont' stay - it's not getting fuel. I would suspect the needle/float is stuck and hung up. If it had nasty ol fuel in there at all - it will need a good cleaning and make sure the needle and float are working.
post #7 of 7 Old 02-01-2016, 10:24 PM
Never a good idea to use starting fluid on a two cycle motor. Its the same as running it on gas only with no oil in the fuel mix. Use a correct gas/oil mix for testing to not cause unnecessary wear by running rings, cylinder walls, bearings dry without lube.
33006 is offline
