MTD Old School - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-10-2016, 06:14 PM Thread Starter
Question MTD Old School
Long time lurker, finally member.
Inherited a snowblower from my father a couple years ago after using it for many years at my parents house.
Long and short the model number is 317E664G525 (10/28). I am looking to see if there are any parts/rebuild kits available. I am located in the Northeast and meant to rebuild this past summer but never got the time.
It starts right up and runs great and does a heck of a job. However, need to get a pull cord and it also makes noise (grinding) when off and pushing forward or reverse...almost like there is a bold or two missing in the gear box..
Just wanted to see if anyone had any information as to how to get parts/possible reason for noise.
Not sure I can post photos..
Any input is very much appreciated!!
J
MAmtd is offline
post #2 of 8 Old 12-10-2016, 06:20 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 466
Likes (Received): 811
Grinding noise sounds like a worn friction wheel. If you give your location, someone local might have a recoil available. GL.
Jackmels is offline
post #3 of 8 Old 12-10-2016, 06:27 PM
e.fisher26's Avatar
Thanks (Received): 50
Likes (Given): 44
Likes (Received): 65
MTD Old School
Online companies like ereplacments.com will have a lot of parts for MTD. Just need model number. I'm guessing u need a friction wheel with the rubber, if the drive plate is too chewd up now u may also have to replace that
e.fisher26 is online now
post #4 of 8 Old 12-10-2016, 08:08 PM
69ariens's Avatar
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Any local dealer should have parts for the engine .You just need to get the ser# and model # off the engine. To check friction wheel tilt blower up and take the cover off under the engine. A lot of brands use the same friction wheel so a dealer could match it up with another brand.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #5 of 8 Old 12-10-2016, 09:28 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 289
Sounds like friction disk, Real easy to do. A lot of vids on you tube on the how to. What part of Ma are you in, if your close I could give you a hand, Just went through cleaning mine a few weeks ago. As for the pull cord, Depending on which one it has, I ordered the wrong one for a different machine that may fit yours, Or if it's just the cord that can be easily changed on the cheap. I have a 100' roll I keep just for doing that.
Dauntae is online now
post #6 of 8 Old 12-10-2016, 10:45 PM
e.fisher26's Avatar
Likes (Given): 44
You guys in ma? What towns?
-efisher-
post #7 of 8 Old 12-11-2016, 04:55 AM
Thanks (Given): 13
Likes (Given): 146
I'm in New Bedford almost on the freetown line
post #8 of 8 Old 12-11-2016, 11:56 AM
e.fisher26's Avatar
Likes (Given): 44
Leominster here..
-efisher-
