Can this be welded? Auger, single stage - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 03-04-2017, 05:38 PM Thread Starter
evh
evh's Avatar
Likes (Given): 62
Likes (Received): 17
See the attached pictures. I realize this is from an inexpensive single stage MTD type, however, everything is in great shape. The auger is as well. It has very little rust on it. It looks to me like the weld just broke.
I am pretty handy but I have never welded before. I have buddy who has, but I wanted some professional opinions from the experts here before I take it to him.
Thanks.
ID:	101426   Click image for larger version
ID:	101434   Click image for larger version
ID:	101442   Click image for larger version
evh is online now
post #2 of 8 Old 03-04-2017, 06:26 PM
Likes (Given): 467
Likes (Received): 480
It can definitely be welded, just make sure that it is as centered as possible before welding it.
post #3 of 8 Old 03-04-2017, 06:39 PM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
Yes. Definitely can be. Clean up the joint with a wire wheel ,line up the parts as straight as you can. A wire feed welder will do the best job.
Prime is offline
post #4 of 8 Old 03-04-2017, 07:38 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 447
Is this a bearing that got frozen and spun?
JLawrence08648 is offline
post #5 of 8 Old 03-04-2017, 07:59 PM Thread Starter
evh
evh's Avatar
Likes (Given): 62
No, bearings look good and spin smooth. My guess is something was hit or just a poor weld to start out with.
evh is online now
post #6 of 8 Old 03-04-2017, 08:17 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 301
By the looks of the break it should fit back into its hole like a puzzle piece. Easy repair.
drmerdp is offline
post #7 of 8 Old 03-04-2017, 08:59 PM Thread Starter
evh
evh's Avatar
Likes (Given): 62
Yep, that is my thinking as well. I'll clean it up and give it to my friend. He will have a guy in the shop at his work weld it. I think it should be as good as new.
evh is online now
post #8 of 8 Old 03-04-2017, 09:07 PM
Thanks (Given): 572
Thanks (Received): 746
Likes (Given): 4233
Likes (Received): 1650
IMHO, The big thing is to make sure you tack it in two or three places and them add some bead but don't try to run it all in one go. It's a matter of spreading out the head so it doesn't change position/warp from too much heat in one area or on one side. When it's made at the factory they likely had it in a jig that held it's position and you can make a nice clean looking once piece weld but as a repair that normally doesn't work so well.
So it may not be pretty but it should hold well and last the life of the machine.
