Auger Backlash - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-10-2014, 09:42 PM Thread Starter
Auger Backlash
How much backlash is acceptable in the auger gearbox on my MTD 800 series? I have about an inch measured at the edge of the auger.
Hank
1986 Landmark (MTD) 26" 2 stage with HM80
hankster1 is offline
post #2 of 3 Old 01-11-2014, 12:11 AM
td5771's Avatar
Likes (Received): 57
I dont think that is too bad. I have a tiller that has a massive cast iron gear box with the same worm gear set up as snow blowers. I thought it had too much play, about 1 1/2 inch.
After adjusting it to what I thought would be an acceptable amount of play i tried it out and it generated a whole lot of heat. enough where I couldnt touch the gearbox.
Needless to say it was adjusted back to where it was. havent had a problem.
If yours is the non adjustable type remember that one inch of travel at the outside tip of the auger translates to a very small amount at the center.
td5771 is offline
post #3 of 3 Old 01-11-2014, 10:35 AM Thread Starter
Thanks for the reply. If that is normal I wont worry about it.
Hank
