2006 Yardworks 5/22 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-23-2017, 02:26 PM Thread Starter
2006 Yardworks 5/22
Hello everyone, new guy here. I picked this Yardworks 5/22 up from the side of the road a few weeks ago. There was a sign on it that said auger doesn't turn, gearbox issue. I didnt really look at it too closely at first. So I tossed it in the truck and took it home. When I got back to the house, First thing I noticed was the Chinese engine. It starts and runs fine, whatever, no big deal. The second thing I noticed was that one of the shear pins was only half broken. Just for testing I put another bolt in to see if the auger would turn. Auger completes maybe 1 rotation and stops. That leads me to believe the worm gear is toast. Now for the biggest problem... I can't find a model number anywhere on this thing so I can order parts. I've heard Yardworks was made by MTD at one point, but they are no longer listed on the MTD website. Any ideas?
ID:	112185   Click image for larger version
ID:	112193   Click image for larger version
Bullitt91 is offline
post #2 of 11 Old 10-23-2017, 04:44 PM
https://www.ebay.com/itm/Genuine-MTD...4AAOSwA3dYdtYg
this is the gear mtd uses in pretty much every 2 stage snowblower they make
post #3 of 11 Old 10-23-2017, 07:54 PM Thread Starter
Thank you! But any idea on where I can find a model number?
post #4 of 11 Old 10-23-2017, 08:05 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
If you can't find your machine on MTD website try to find it on Partstree. Also if you call MTD customer service they will help you with parts #. They have machines not listed on their website.
JLawrence08648 is offline
post #5 of 11 Old 10-23-2017, 08:39 PM Thread Starter
Thank you!
post #6 of 11 Old 10-29-2017, 11:00 PM Thread Starter
Bought this gear. Way too small.
Got mine torn down finally, and found this...
ID:	112745   Click image for larger version
ID:	112753   Click image for larger version
ID:	112761   Click image for larger version
post #7 of 11 Old 10-29-2017, 11:02 PM Thread Starter
Know of any other part numbers that would match the gear I pulled out? I couldn't find a number anywhere on it.
post #8 of 11 Old 10-30-2017, 12:49 AM
looking at it again with the chinese engine it may be an mtd clone
post #9 of 11 Old 10-30-2017, 09:44 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 289
That was my thought, other than the more recent made Iíve only seen Tecumseh engines on MTD Might be able to mod a MTD gearbox in there but the cost may be more than its worth
Dauntae is online now
post #10 of 11 Old 10-30-2017, 10:04 AM
Thanks (Received): 385
Likes (Given): 177
Likes (Received): 892
Considering its from 2006, it seems unlikely the snowblower body is a MTD clone..
Its more likely to be a "real" MTD, with a replacement engine..
sscotsman is offline
