New Carb on Tecumseh 8hp Snow King - Runs Full Choke Only - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-26-2017, 05:46 PM Thread Starter
Pretty much like the title states. New carb and new fuel line. New primer bulb fuel line as well. When I prime it I'm thinking I hear it suck a bit of air. Can't recall if I've heard this before because the machine always ran great until I found the leaking primer lime.
Only runs on full choke. Newer style carb with 1/2" bolt on bottom of bowl. No adjustment pin on bottom of bowl. Played around with mix screw on side of carb body with no luck. Begins to stall when I take it off full choke. Thinking I'm not getting fuel to carb but as mentioned, I replaced everything. Don't think I crimped the main fuel line when I replaced the old one.
cqlink is offline
post #2 of 4 Old 12-26-2017, 05:54 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
i would look for an air leak.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 4 Old 12-26-2017, 06:01 PM
1132le's Avatar
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
check the float level even on a brand new carb its best to pull the bowl and check the float etc before installing it
much easier off the machine then on
1132le is online now
post #4 of 4 Old 12-26-2017, 07:54 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
The screw on the side is non-adjustable, it's a jet, needs to be tighten, not a mixture screw.
Spray some starting fluid at the intake gasket, maybe a leak there. Otherwise follow the advice above. Defective carb? Somehow dirt in one of the holes?
Remove the fuel bowl, see how fast fuel is leaking out.
JLawrence08648 is offline
