MTD Yardworks 8/24 for $450 - good price? - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 12-26-2017, 11:39 PM Thread Starter
Hello all,
I'm looking to replace my vintage Toro snowblower with a newer (but used) one. I came across someone selling an 8/24 Yardworks for $450, and it seems to be about 5 years old. Is this a good price? Are there any known issues I should keep an eye out for when I check it? Unfortunately the seller didn't provide me with a model or serial number.
Thanks in advance!
Versys514 is offline
post #2 of 17 Old 12-26-2017, 11:49 PM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1853
Likes (Received): 647
you could do a lot better with $450
Thanks Versys514 thanked for this post
post #3 of 17 Old 12-26-2017, 11:50 PM
1132le's Avatar
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Originally Posted by Versys514 View Post
Hello all,
Thanks in advance!
Brand new it was close to 500 very under powered poor build quality i woudnt pay more then a 100 but i woudnt buy it at all
around here you can get a ariens st824 from 200 to 400
1132le is online now
post #4 of 17 Old 12-26-2017, 11:56 PM Thread Starter
I should probably have qualified that it's $450 CAD so that might be a little more reasonable. Thanks for the input, I'll keep looking.
post #5 of 17 Old 12-27-2017, 01:21 AM
stay far away from mtd. you could get a nice ariens st824 for around 300 where i live, i sell them completely serviced for 400
post #6 of 17 Old 12-27-2017, 09:17 AM
Thanks (Given): 224
Likes (Given): 1853
save your $450 and keep looking for a newer toro, ariens, Honda, or Yamaha! put a little more $$$ in the snowblower fund while looking and what's wrong with the toro you have
post #7 of 17 Old 12-27-2017, 09:20 AM
Clutch Cargo's Avatar
Thanks (Given): 80
Thanks (Received): 35
Likes (Given): 96
Likes (Received): 94
IMHO, $450 is a lot for a lot of unknowns. I think you should find out exactly what year it is. Large frame machines from the 90s through the early 2000s were not bad machines despite what some may say. Do a little research, make a reasonable offer, and if he balks, walk away.
2015 Ariens Deluxe 28
Previous Machines:
1995 Yard-White-Bilt 8/26 Frankenblower
1980 Toro 826
1981 Toro 3521
Clutch Cargo is offline
post #8 of 17 Old 12-27-2017, 09:36 AM
Likes (Received): 1345
I would pass, way to much green for that machine!!!!!!!!!
post #9 of 17 Old 12-27-2017, 09:46 AM Thread Starter
I posted this other thread
here
. Starter and carb. I'm also looking at a pull start option as the electric starters seem to be notoriously difficult to find.
Thanks for your suggestions!
post #10 of 17 Old 12-27-2017, 10:19 AM
Thanks (Given): 229
Thanks (Received): 198
Likes (Given): 2027
Likes (Received): 515
here
Man...just about any other snowblower will feel like a toy after using a Toro 10/32 for so long. Awesome piece of equipment.
This guy here has a 12V setup.
It looks like it still uses the updraft Carb. They're very easy to rebuild/clean. The only tricky part can be removing the emulsion tube (you do that before splitting the carb body in half). I recommend purchasing the proper screwdriver since it's brass and can distort quite easily...you can make your own but it needs to fit perfectly without damaging the head or the carb body threads.
('87 Toro 38150 826)
classiccat is online now
