Electric start on Tecumseh HMSK 80-110 not engaging - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 18 Old 02-01-2018, 06:51 PM Thread Starter
Thanks, That is the way I was kinda seeing it........ just hoping to avoid removing the tank.
Oh well, tomorrow is supposed to be warmer.
much obliged
Jimea is offline
post #12 of 18 Old 02-01-2018, 07:23 PM
Dannoman's Avatar
Thanks (Given): 8
Thanks (Received): 19
Likes (Given): 45
Likes (Received): 121
Removing the tank is not a biggie. Just make sure you carefully remove the fuel line or you can tear your gas line and get a new problem to solve. Also use Locktite. I didn't on my last starter and it snapped off at one of the lower bolt tabs.
Dannoman is online now
Thanks Jimea thanked for this post
post #13 of 18 Old 02-01-2018, 07:51 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
Remove the flywheel housing, you don't need it, now you have a view of everything including when you engage it if you get that far.
post #14 of 18 Old 02-01-2018, 09:26 PM Thread Starter
I'll keep that in mind. Yay - these are the ideas that may solve my problem.
Jimea is offline
post #15 of 18 Old 02-02-2018, 02:17 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 182
fuel tank is easier to remove than the starter, 2 screws and a 1 fuel connection, done. maybe have some 1/4" i.d. fuel line just in case old one is breaks due to age. fuel tank might be in the way if installing starter so its a no brainer to remove it if thats the case.
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #16 of 18 Old 02-03-2018, 04:30 PM Thread Starter
Yay!! Thank you all for your help & suggestions - WE WON!
After removing the fuel tank, I was able to (with a little force & jiggle) slip the starter into place and screw in the bolts with a thread locker. Put the fuel tank back on and starter worked great.
The lower bolts that came with the replacement starter were metric so I had to go buy an open end 10mm wrench.
THANK YOU All again.
Jim
Jimea is offline
post #17 of 18 Old 03-07-2019, 02:11 PM
Originally Posted by contender View Post
JIMEA------ I have a working 110v starter, that came off a MTD built, with a 8 hp Tecumseh motor.
In the Kitchener area, if you are interested.......
Hi there contender, if you still have that Tecumseh starter, I would be happy to take it off your hands. Let me know how much you would sell it for? I am new to the forum, wanted to say thanks for all the tips
Tony is offline
post #18 of 18 Old 03-07-2019, 05:53 PM
Thanks (Given): 27
Thanks (Received): 21
Likes (Given): 117
Likes (Received): 40
Tony, where are you located? shoot me a PM if you want.....
contender is online now
