Mtd model 316-611-d000 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-01-2018, 06:34 PM Thread Starter
hello im new to the forum and had a question about a mtd snow blower listed above. i owned this for 20 years plus the problem im having is it is hard starting and once it gets started it will only run when choke is half way and when you turn the choke in normal position to run it will stop and start to backfire.and when i try to start again it goes through the same procedure. i put new plug. all help will be appreciated!
thank you
glc4123 is offline
post #2 of 6 Old 12-01-2018, 06:57 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Carburetor is dirty, easiest for you is to buy another off eBay.
JLawrence08648 is offline
post #3 of 6 Old 12-01-2018, 07:47 PM
malisha1's Avatar
Likes (Received): 32
Take the bottom bolt underneath the carburetor bowl off and clean the small holes in the bolt. Try not to take off the bowl.
malisha1 is offline
post #4 of 6 Old 12-02-2018, 07:14 AM Thread Starter
thanks for the help
glc4123 is offline
post #5 of 6 Old 12-02-2018, 10:02 AM
malisha1's Avatar
Did it work?
malisha1 is offline
post #6 of 6 Old 12-07-2018, 10:53 AM
Likes (Received): 22
Been waiting for the OP to post back since that's the same blower I have but if he's owned it for all this time and this is the first time he's had issues starting it I'm impressed. My carb started acting up about 10 years ago and I've always used E0 and sta-bil.
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
