850W Oil Drain Tube - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-27-2018, 04:28 PM Thread Starter
850W Oil Drain Tube
I was doing an oil change earlier and could not get the nut off the end of the drain tube. The tube itself spun out of the engine so I was able to get the oil change done, but the person who sold me the machine must have bent the tube a little because it was definitely spinning out in a large circle. Does anyone know where to get a replacement tube or by any chance know what the thread size is? At least then I could just hit up Lowes for a pipe or make my own.
Thanks in advance.
owen996 is offline
post #2 of 6 Old 12-27-2018, 04:34 PM
Likes (Received): 1345
Thanks in advance.
DRAINZIT Has an app for what ever engine is that you have on there. ALOHA From The Paradise City.
post #3 of 6 Old 12-27-2018, 05:11 PM Thread Starter
I checked there after seeing a bunch of positive responses. Unfortunately, they don't show anything under the Tecumseh engine section.
owen996 is offline
post #4 of 6 Old 12-27-2018, 05:29 PM
As far as I know it would either be a 1/4 or 3/8 on those.
post #5 of 6 Old 12-27-2018, 06:33 PM
Thanks (Given): 7
Thanks (Received): 32
Likes (Given): 411
Likes (Received): 116
1/4 inch NPT on a tech i use 2 pipe wrenches one to hold the pipe the other to spin off the cap .
132619 is offline
post #6 of 6 Old 12-27-2018, 07:05 PM Thread Starter
I'll try the 1/4 inch Drainzit first and see if that works. I put a set of vice grips on the pipe and tried the cap but it still spun the pipe 3 times. Thank you both!
owen996 is offline
