Upgraded Underdog of 2016 - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-03-2019, 02:41 AM Thread Starter
Likes (Given): 7
Likes (Received): 14
Happy New Year to you all,
I’ve been following SBF for a few years now and find you all to be an informative, nice little community of people who (like me) like to work on and take care of their own stuff.
I titled this thread Underdog, cause let’s face it, most of you wouldn’t recommend an MTD product (these days) and for the most part I can’t argue that, however they do have their place, but now they’re build quality is mostly for the homeowner or contractor that only takes care of their own home, but that’s only after the wife gets on his case to “getter dun”. Neither one wants to or cares to or doesn’t make the time to take care of their equipment. As a result they fail. They fail more than they should or would if they actually took care of them. I’m of the belief that nothing is built the old school way “nothing” and will fail if not properly maintained. Me personally, I work on residential homes for a living (33yrs so far) and like to work on my own equipment as a pass time or in my spare time.
Having said all that, MTD did away with two previous machines, a 33”- 357cc & 45”- 420cc. personally I wouldn’t have bought either one of those machines. MTD changed, upgraded and replaced those two machines in 2016 with a 30”- 357cc & a 34”- 420cc. These two machines are sized more appropriately. The gear box is twice as large with a steel brace bolted to the top of the gear box and welded to the housing. Both newer machines are built identically with the exception of housing width/cc. Both machines are painted two different colors and labeled as either a Troy-Bilt Artic Storm or a Craftsman Pro with different trimmings.
These machines are built in the U.S. with Powermore engines made in China. Ariens & Husqvarna LCT engines are made in China, and Toro’s Loncin engines are also made in China. Most likely all the B&S engines are now made in China. In fact one would be hard pressed to find a snow blower with a U.S.A. made engine. All these China engines are built to the specs of the American engineers that designed them. To be fair, this is the world we live in and if we had all American made products (through & through) available to us, we’d be paying Honda prices on everything we own.
Ok, so the Underdog I purchased was the Craftsman Pro 34” with a 420cc motor and would like to know if you guys would of come to the same conclusion that I have, that these 2 new machines are an improvement and stand out in the MTD family?
This machine has;
• A hand crank that will completely turn the shoot 200 degrees in 2 rotations.
• 14”- 4 blade impeller & 14” auger flights.
• 16” x 6.5” tires.
• 1 lever for deflector & one for 6 forward & 2 reverse (I adjusted reverse speed).
• 7 LED lights, 1 in dash & 6 mounted on top of auger housing (important to me).
• Entire machine has thicker steel, it’s heavy.
• 1.3 gallon poly tank
• Trigger steering
Check out the following specs & pics;
Gauged steel using Vernier caliper & converted using chart via Google
Auger housing (both sides & top) - 13 ga
Support brace joining gearbox to auger housing - 7 ga
Shave plate - 7 ga
Impeller housing – 13 ga
Auger flights – 11 ga
Impeller blades – 11 ga
Transmission box – 13 ga
Welded L brackets joining impeller housing to transmission box - 11 ga
Chute & deflector – 16 ga
Hanging Chute support mast – 11 ga
Shifting levers – 11 ga
Rims – 11 ga
Looking forward to hearing what you all think. Perhaps now that our blowers are out some of you can check the gauge thickness of the steel, I’m curious about the other brands.
Thanks.
ID:	150907   Click image for larger version
ID:	150909   Click image for larger version
ID:	150911   Click image for larger version
ID:	150913   Click image for larger version
ID:	150917   Click image for larger version
ID:	150919   Click image for larger version
Stability is offline
Likes Grunt liked this post
post #2 of 22 Old 01-03-2019, 05:20 AM
Thanks (Given): 7
Thanks (Received): 32
Likes (Given): 411
Likes (Received): 116
each to their own, yes cared for properly all run as made.craftsman blowers have in the past been made by both MTD and husky,
https://movingsnow.com/2012/whats-the-difference/
132619 is offline
post #3 of 22 Old 01-03-2019, 06:45 AM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
Time will tell.
DriverRider is offline
Likes 132619 liked this post
post #4 of 22 Old 01-03-2019, 08:44 AM
Thanks (Received): 205
Likes (Received): 758
I think you'll get a lot of use out of her...the MTD's I've come across were functional and if kept up were fine. I think working on them is easier at times and the parts are cheap and available
cranman is online now
post #5 of 22 Old 01-03-2019, 08:46 AM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
Stanley just purchased MTD, I saw this in another thread. I think this will improve their quality. Maybe this is the first sign of that.
jsup is offline
post #6 of 22 Old 01-03-2019, 09:06 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
What's up with the stabilizers for the auger housing? Why is that? I think I know the answer.
russ01915 is offline
post #7 of 22 Old 01-03-2019, 09:10 AM
Thanks (Given): 21
Likes (Given): 254
That has been my experience, and is 100% accurate. It's all about the maintenance.
jsup is offline
post #8 of 22 Old 01-03-2019, 09:35 AM Thread Starter
Likes (Given): 7
Yes I agree, the design is simplistic. It's been around for a very long time and just works, that's why it's still used to this day. The gearing is robust and if kept clean and lubed, should continue to work smoothly.
Yes, parts are reasonably priced and available. I made sure of this prior to purchase knowing that Sears may go under soon. For those who are curious, on all Craftsman and Troybilt units there's an MTD model number on the sticker. I've called MTD Tech several times and never had to wait longer than 60 seconds to be speaking with an American Man based in Ohio, friendly & willing to help, answer my questions and emailing me service manuals for both engine and machine. I've also went on their website and opened up 2 browsers, 1 for the TB arctic storm and 1 for the Craft Pro, went through page by page taking note of the identical part numbers for both machines. One can buy any and all of the parts direct from MTD. I was also told by MTD and my local dealer as long as it has a MTD model # they can work on the machine under warranty the same as if it was a Troybilt.
post #9 of 22 Old 01-03-2019, 10:00 AM Thread Starter
Likes (Given): 7
I believe Stanley bought into MTD, they didn't buy the whole company, at least not yet. They did this because they bought the Craftsman "name" and are building there own craftsman named machines, which are different then the Craftsman machines at Sears.
Having said that, I don't put much stock in Stanley, they have trashed many American brands they've bought in the past, 2 examples are Delta and Porter Cable.
post #10 of 22 Old 01-03-2019, 10:13 AM
Thanks (Given): 19
Likes (Given): 107
Stanley made tape measures for Craftsman for years. Then one day, they stopped and they stopped the lifetime guarantee on them. This was about 3 years ago.
