Surging on Idle and Load - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-28-2019, 10:50 PM Thread Starter
I have a Yardman model number 31ae5klf701 with a Tecumseh lh358sa 159502z engine. I have replaced the carburetor with a new adjustable carburetor https://www.amazon.com/dp/B01D40658I..._-77tCbV52SY3B and brand new gaskets. Also replaced the fuel line but still having noticable surging both under load and idle. Any ideas why?
banders5144 is offline
post #2 of 18 Old 01-28-2019, 10:55 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Make sure you have no water in your gas tank and gas can then adjust the governor.
post #3 of 18 Old 01-29-2019, 12:38 AM
Dannoman's Avatar
Thanks (Given): 13
Likes (Given): 50
Likes (Received): 124
Bad gas can do that. You might also have a defective gas cap that isn't venting properly. Does it still surge if you run it with the gas cap still on but unscrewed so it isn't airtight? If so, the culprit is the gas cap. Just buy a new one. Or you can drill a small hole into the defective one for now.
Dannoman is offline
post #4 of 18 Old 01-29-2019, 02:37 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
but did u adjust the high and low speed jets?
donyboy has a vid on that
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #5 of 18 Old 01-29-2019, 06:57 AM Thread Starter
I only use TruFuel and I emptied out the gas tank. It surges with the gas cap on or off.
post #6 of 18 Old 12-12-2019, 04:11 PM Thread Starter
Any other ideas? Brand new gas tank, trufuel 4 cycle gas, tries both new adjustable and fixed jet carburetor. Still surges pretty bad on idle, on full throttle not so bad.
post #7 of 18 Old 12-12-2019, 05:45 PM
ST1100A's Avatar
Thanks (Given): 182
Thanks (Received): 124
Likes (Given): 313
Likes (Received): 235
Float could be out of adjustment or slow speed circuit clogged somewhere causing a lean condition. Check your valve clearance while you are at it, a tight valve could do that also.
ST1100A is offline
post #8 of 18 Old 12-13-2019, 02:10 PM Thread Starter
Even if it's a brand new carburetor? Straight out of the box?
post #9 of 18 Old 12-13-2019, 02:17 PM
Thanks (Given): 26
Likes (Given): 83
Likes (Received): 240
Chinese carb? *EVERYTHING* is in doubt, since QA is often so poor. Might also check that gov linkage(s) are not binding, since that can cause it to overshoot and surge as well
tadawson is online now
post #10 of 18 Old 12-13-2019, 02:18 PM
ST1100A's Avatar
Thanks (Given): 182
Likes (Given): 313
Yes a brand new carb out of the box can have problems, a float stuck, or needing adjustments, and fuel mixture screws needing adjustments. Some brand new carbs are bad right out of the box, especially one of those super discounted carbs you have to be careful with, the super low price sometimes tells you to stay away from them.
ST1100A is offline
