Won't go in light snow - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-29-2019, 10:58 PM Thread Starter
Hi everyone,
I have a 2007 white outdoor 8.5hp Tecum snowblower and for years i have had this problem that when i blow light fluffy snow the snowblower will suddenly stop pulling itself along. I have replaced the friction wheel twice but i no change, i can't figure it out ! Any ideas ?
BMoney80 is offline
post #2 of 9 Old 01-29-2019, 11:32 PM
Motor City's Avatar
Thanks (Received): 50
Likes (Received): 54
The wheel has to be slipping. Is the belt cover and bottom pan on? water getting on the friction disc/wheel? Also check the cable, may need more tension.
Ariens ST11528LE
Honda HS720
Motor City is online now
post #3 of 9 Old 01-30-2019, 01:36 AM
Without seeing inside the drive unit I'd have to guess:
Check for play in the drive axle. I've seen worn bushings cause this in MTD units. The strain of heavy snow can alter how a loose axle behaves.
stanz is offline
post #4 of 9 Old 01-30-2019, 01:54 AM
Thanks (Given): 522
Thanks (Received): 694
Likes (Given): 3916
Likes (Received): 1510
Just to be clear, the wheels stop turning ?
When you see it happen is there and smoke coming from the belt area or transmission ?
post #5 of 9 Old 01-30-2019, 09:24 AM
Jackmels's Avatar
Thanks (Given): 121
Thanks (Received): 173
Likes (Given): 389
Likes (Received): 723
Check the Idler Pulley that Tensions the drive Belt. Might be a Broken or worn Spring.
Jackmels is offline
post #6 of 9 Old 01-30-2019, 11:59 AM
Thanks (Given): 92
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 421
You have to find out where it's slipping starting with the engine and drive pulley moving to the underside, friction disk, wheels. It's easier with 2 people, one operating, one watching.
post #7 of 9 Old 01-30-2019, 12:56 PM
vmax29's Avatar
Thanks (Given): 17
Likes (Received): 86
If the springs, belt and friction wheel are good they might be glazed over. I used to have that same problem with my old Troybilt when it hit the water at the curb. I used some belt dressing spray on the friction wheel and it worked great again.
vmax29 is online now
post #8 of 9 Old 01-30-2019, 01:01 PM
Thanks (Received): 57
Likes (Given): 63
Likes (Received): 191
i worked on a machine in the fall that had a sticky idler wheel on the belt tensioner. stopped the machine from being able to move at all. definitely need to look things over and see what is slipping or not allowing the machine to drive.
yardworks 31AH6WKF515
crazzywolfie is online now
post #9 of 9 Old 01-30-2019, 02:22 PM
Thanks (Received): 44
Likes (Received): 113
You may want to check the bushings on the swing deflector plate that holds the drive hub ( the 2 pins that allow it to swivel). and as well the return tension spring for the same.
Lottstodo is offline
