What to know to install replacement engine PowerMore 357cc. - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 16 Old 02-18-2019, 10:26 AM Thread Starter
Originally Posted by drmerdp View Post
What!! Thatís bananas. Did you check with the manufacturer directly? The engine can not be the cost of a whole new snowblower.
Ya I did, here is what the manufacture lists.
johnnyh55 is offline
post #12 of 16 Old 02-18-2019, 11:13 AM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 298
Looks like a predator 420 is in your future.
drmerdp is offline
post #13 of 16 Old 02-20-2019, 03:15 PM Thread Starter
Since the predator 420 does not have 120v ac electric start i found another engine that is 420cc with AC electric start. For the shaft size I can get an adapter onpy if i meed to upsize? You can't get an adapter to downsize I assume? So i just need to make sure the bolt pattern matches so the alignment of pullies stays the same? Also this new engine does not have onboard throttle control, instead it has a remote throttle cable can I just buy a throttle control and mount it anywhere?
Sent from my SM-G960W using Tapatalk
post #14 of 16 Old 02-21-2019, 08:30 PM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 121
This is half the cost of a new 357.
https://www.ebay.com/p/MTD-Cub-Cadet...1378616&chn=ps
SimplicitySolid22 is offline
post #15 of 16 Old 02-21-2019, 09:13 PM
WVguy's Avatar
Thanks (Received): 40
Likes (Received): 160
But look at the details:
MTD Cub Cadet 483-SUC 357CC (13HP) Snow Blower Engine. Fits Cub Cadet Snow Blower models of 2X and 3X. This engine has minimal wear as it was warrantied after 2 Hours. Engine had a sheered flywheel key and has been replaced and tested. Like new condition and is fully functional. See pictures for wear.
7/8" diameter for crankshaft. 2 1/4" from end of crank to bevel of crank. 4 3/4" from base of engine to bottom of crank.
All whole engines that are sold may need to have carburetor service and/or parts due to fuel being drained from engine for shipping. Customer assumes all costs if carburetor needs service or parts - we will not pay for or reimburse customer for the maintenance issues. Sold as is, no warranty or returns - all engines tested and verified working.
Sooo - we tested it and it ran, but by the time you get it, it might be missing parts that make it run and if that happens it's your problem.
No thanks, I'll pass.
WVguy is offline
post #16 of 16 Old 02-22-2019, 01:16 AM
Likes (Given): 74
No worries....was nice to find a 357cc....
They did not say it might be missing parts they are saying it may need to have carburetor service and/or parts due to fuel being drained from engine for shipping.
I believe if any parts they mean are if carb needs a tune up.......Nothing will be missing. That is a disclaimer.... Probably better to be safe.
Yeah go for a predator....will treat you well!!!
Similar Threads
Troy Bilt Storm 5524: engine swap or replacement? HotChoc42 Snowblower Repairs and Maintenance Forum 32 03-15-2017 02:05 PM
New from maine with engine replacement ???? SCRAPPYDOO New Member Introductions 3 11-05-2013 04:33 AM
replacement engine for ariens 924044 winginit General Snowblower Discussion 4 02-10-2012 05:44 AM
Looking for replacement engine SumoLumo Snowblower Repairs and Maintenance Forum 4 12-02-2011 02:31 PM
replacement engine s4silver1 Snowblower Repairs and Maintenance Forum 13 01-13-2011 07:40 PM
