What to know to install replacement engine PowerMore 357cc. - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-15-2019, 10:33 AM Thread Starter
My aunt has a White snowblower that she did her own oil changes every season but last season she didn't tighten the drain plug so it came loose and the engine ran without oil since it doesn't have a low oil shutdown switch. Now the engine is blown so it doesn't start and I was looking at a replacement engine like a Predator but what do i need to take into consideration to replace her old engine with an aftermarket one? I know I need to check for 120V electric start but do I need to measure the bolt pattern of the powermore 357CC to make sure the predator engine matches it? And what about the crankshaft output size, does it need to be the same or can you get adapter for it to convert it to whatever size is needed? Is there anything else I need to consider? I see some engines have a cable for throttle that comes with them but this powermore does not have a remote throttle. Also do I need the exact same CC of engine or go bigger or smaller without issues?
johnnyh55 is offline
post #2 of 16 Old 02-15-2019, 02:04 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 301
How much is a replacement powermore? Might be easier to simply call and order one from troybilt/cubcadet?
drmerdp is offline
post #3 of 16 Old 02-15-2019, 02:33 PM Thread Starter
Dealer said close to $1000, not worth buying, might as well buy a new blower hence the reason I am looking at a predator.
post #4 of 16 Old 02-15-2019, 02:39 PM
Thanks (Received): 208
Likes (Received): 764
Might help us if we knew what engine you have on it now....for example, if she has the 8 hp Tecumseh, the 212 Predator is the easiest swap. and almost the cheapest. I just had a 208 cc winter motor made for MTD delivered to my house for $79....The bigger motor is nice, but probably problematic to swap unless you are experienced. The 208 cc motor was on e-bay, and they had some snow ready engines with electric start cheap there as well. If you have a 24 inch blower the 212 or 208 is plenty
cranman is offline
post #5 of 16 Old 02-15-2019, 03:08 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 76
Likes (Received): 128
I have a re-powered Montgomery Ward Gilson made 8/26 which runs a Predator 212cc on it and it works great so a Predator 212cc is good for any application where a Tecumseh or Briggs 8hp engine was used. Now for a 32 inch blower get at least a 301cc Predator. Hopefully the White snowblower used a single shaft engine if so it's a piece of cake to replace the engine.
GustoGuy is offline
post #6 of 16 Old 02-15-2019, 03:12 PM
GustoGuy's Avatar
Thanks (Given): 47
I have a re-powered Montgomery Ward Gilson made 8/26 which runs a Predator 212cc on it and it works great so a Predator 212cc is good for any application where a Tecumseh or Briggs 8hp engine was used. Now for a 32 inch blower get at least a 301cc Predator. Hopefully the White snowblower used a single shaft engine if so it's a piece of cake to replace the engine. As to electric start not available on Predator 212cc. The Predator 420cc has a DC electric start option were you can use a small snowmobile 12 volt battery if you need electric start. However the Predator 212cc usually starts on 1 to 2 pulls of the recoil. I started my Predator 212cc on the Montgomery Ward on the weekend and it fired in just 2 pulls after sitting for 2 years now that shows you how easy the Predator 212cc are to start.
GustoGuy is offline
post #7 of 16 Old 02-15-2019, 04:14 PM
drmerdp's Avatar
Likes (Given): 24
What!! Thatís bananas. Did you check with the manufacturer directly? The engine can not be the cost of a whole new snowblower.
drmerdp is offline
post #8 of 16 Old 02-15-2019, 09:40 PM Thread Starter
The current non working engine on the snowblower is a Powermore 357cc like this one. The blower is a White 30".
Sent from my SM-G960W using Tapatalk
post #9 of 16 Old 02-15-2019, 09:46 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Where are you located?? Is used a possibility??? I have at least one of those used engines on the shelf.
GLuck, Jay
JayzAuto1 is online now
post #10 of 16 Old 02-15-2019, 10:23 PM
GustoGuy's Avatar
Thanks (Given): 47
A 301cc Predator could likely handle the load on a 30 inch blower. I have a Predator 212cc on my Montgomery Ward 8/26 by Gilson and it works great on that machine even the heavy wet stuff but I doubt that the Predator 212cc would handle the 30 inch bucket machine with wet snow. If you need electric start the Predator 420cc with 12 volt start would be a beast on a 30 inch bucket and they are about $359.99 or so at Harbor Freight.
GustoGuy is offline
Similar Threads
Troy Bilt Storm 5524: engine swap or replacement? HotChoc42 Snowblower Repairs and Maintenance Forum 32 03-15-2017 02:05 PM
New from maine with engine replacement ???? SCRAPPYDOO New Member Introductions 3 11-05-2013 04:33 AM
replacement engine for ariens 924044 winginit General Snowblower Discussion 4 02-10-2012 05:44 AM
Looking for replacement engine SumoLumo Snowblower Repairs and Maintenance Forum 4 12-02-2011 02:31 PM
replacement engine s4silver1 Snowblower Repairs and Maintenance Forum 13 01-13-2011 07:40 PM
