Worth doing an engine swap? - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 02-18-2019, 06:01 PM Thread Starter
Swenny's Avatar
Hey everyone. Lots of good info on here.
I have a MTD 31A-3BAD729 snowblower with a Tecumseh 5.5HP (195cc). Engine model is LH195SP-67517D. I believe it's from about 2004 or 2005. It's one of those where it has the swinging bars for controlling it. One for the auger, one for the drive. No speed controls.
The engine has a single horizontal shaft with 2 pulleys on it, which seems like it could be a good candidate because it would not require a lot of changes. Can anyone provide some opinions on this? Will I really see a large boost by *only* adding 1HP/17cc?
Thanks!
Swenny is offline
post #2 of 18 Old 02-18-2019, 06:33 PM
Thanks (Received): 112
Likes (Received): 297
Thanks!
Does the existing engine still work well? It' not that old and if its not broken, why fix it?
That said, putting a more power engine on it cannot hurt anything. The OHV engine is a better breathing engine. Just be sure to measure everything properly so you don't create problems with belt length, alignment etc.
Work fascinates me.
skutflut is offline
post #3 of 18 Old 02-18-2019, 06:41 PM Thread Starter
Swenny's Avatar
It has worked just fine for the 10 years that I have owned it other than replacing a couple of belts. I live on the corner of a cul-de-sac so I get all of the stuff from the side of lot as well as the front. I got to use my neighbor's Ariens Compact 24 with a 9HP motor to clear it the last time and just watching it fling the snow over the 3 foot mounds with ease just made me wonder if I can get a little more power out of mine. Right now I barely can clear the sides when I go down the middle of my driveway.
Swenny is offline
post #4 of 18 Old 02-18-2019, 07:48 PM
Thanks (Received): 208
Likes (Received): 764
Just me...but I would sell the MTD and buy a used 924 series Ariens with the features you want......look at any ST 824...you'll be happy.
cranman is offline
post #5 of 18 Old 02-18-2019, 08:40 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Your snowblower is very low end and lacks the power of others as you have noticed from your neighbors. It lacks the multi speeds that other snowblower have. You have only one speed from a lightweight transmission that is subject to failure where most snowblowers use a friction disk that has a proven track record for 70 years. I don't like how the auger cable hooks to the bail bar exactly the same as a lawnmower with that twisted "L" "S" shaped lead which breaks. Also there is a plastic piece that acts as a clamp for the drive cable housing that breaks and cracks, sometimes when being replaced.
I would sell it and use the money to buy something else. There is a market for this type of snowblower as it is lightweight and folds, taking up a smaller footprint in a shed. And this is a great snowblower for someone who only has a car and has multiple properties to do and wants to put it in their trunk. I know it fits in the trunk of a Honda Accord because I own the same snowblower we are talking about, that's why I know yours well.
JLawrence08648 is offline
post #6 of 18 Old 02-18-2019, 09:24 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 77
Likes (Given): 77
Likes (Received): 127
If you can't fix the power easy you might wan't to think about what others have said...maybe sell and look around for a little more power on a Snow blower that you might like that is similar to your neighbors.
SimplicitySolid22 is offline
Thanks JLawrence08648 thanked for this post
post #7 of 18 Old 02-18-2019, 11:20 PM
Thanks (Given): 572
Thanks (Received): 747
Likes (Given): 4236
Likes (Received): 1655
to SBF Swenny
That thing just shouldn't be sold in Minnesota or anyplace this far north. It's just not made to handle what we get. Bigger engine will help but you'd be way ahead with less frustration just selling it and applying the money to a good used Ariens, Toro, even a Craftsman or MTD that's two stage and with multiple speeds forward and back.
Might be good for clearing off a deck but a driveway would be a bit much and especially the EOD pile from the plow. You'd get a whole week of workout just trying to clear that.
post #8 of 18 Old 02-20-2019, 09:40 AM Thread Starter
Swenny's Avatar
Thanks everyone for the replies, even JLawrence08648's criticism
The nice thing about this model is that I can wheel it between the two cars in the garage. I can probably fit a 24 in there also, but I'm not sure about a 26. I'll keep looking around.
Swenny is offline
post #9 of 18 Old 02-20-2019, 10:51 AM
Thanks (Given): 95
Likes (Given): 74
Swenny, Thanks for being a Gentleman, I came down hard with my criticism about your snowblower in my initial response then I edited my response.
You buy a snowblower width on the area you need to clear. If you decide to go for a 24" width, many have a 5hp 212cc engine, consider going larger 7hp-8hp, 250cc; same for a 26" width, go larger. It will handle the deeper snows better but more importantly the wet snows better, and do it faster.
post #10 of 18 Old 02-20-2019, 10:59 AM
tdipaul's Avatar
Thanks (Given): 79
Thanks (Received): 82
Likes (Given): 321
Likes (Received): 348
Hey now, don't get touchy. You asked for opinions.
1989 John Deere 1032
tdipaul is online now
Similar Threads
Toro 421, Predator engine swap? frankjc Toro Snowblowers 20 01-08-2016 11:26 AM
Toro 826OE engine swap bosco659 Toro Snowblowers 5 03-10-2014 07:15 AM
Tecumseh Engine Swap NWCanuck MTD Snowblowers 15 10-23-2013 11:45 PM
Engine swap RocketPower Ariens Snowblowers 27 02-27-2013 07:34 AM
Engine swap swampjeff General Snowblower Discussion 4 01-01-2011 02:27 PM
