Am I to far gone - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 23 Old 02-01-2020, 10:08 PM
Thanks (Given): 230
Thanks (Received): 199
Likes (Given): 2034
Likes (Received): 516
That's awesome! The machine looks like it just rolled out of Walmart in 2005!
Full tear-down and rebuild if it were me.
I'd want to peek inside of that sump and give the crank and cam a good inspection and also remove the rings to give the piston a super thorough clean; those ring journals are probably packed with crud. There's a special order that those rings go so keep track; IIRC the compression (top) ring has a chamfer.
you can buy gasket kits that have the sump, breather, muffler, intakes and head.
('87 Toro 38150 826)
classiccat is online now
post #12 of 23 Old 02-01-2020, 10:35 PM
Thanks (Given): 28
Thanks (Received): 58
Likes (Received): 106
Originally Posted by Mt.Hood View Post
I was given this guy by my neighbor. Said he used it around 6-7 times then parked it and got a tractor. It has sat outside in the rain for at least 2 years. It was full of water. I got it unfrozen,piston travels and both valves move. Not sure if there is anymore water under the piston. Piston walls do not appear to have any scoring but there is rust from all the water. Carb and tank have been cleaned and oil drained. At this point what should I do? Thanks for any help.
I see some debris under a valve in the last photo..be sure to get that out.
As far as the bore condition...keep cleaning and clean some more.. I would use a light oil such as kerosene ..to keep the particles from going past the piston..plastic brush or similar.
Clean the valve seats with the valves open..work your way around.
I think you can get it running..but it will burn oil.
Edit
I just looked again and zoomed in.
It's not as bad as it looks..little more cleaning and its good(20minutes)...be sure to clean valve seats up as well.
Oil consumption will be acceptable I think.
Shovel is online now
post #13 of 23 Old 02-02-2020, 02:58 AM
ST1100A's Avatar
Thanks (Given): 183
Thanks (Received): 124
Likes (Given): 338
Likes (Received): 236
It looks like it will take some time and a lot of clean up work and it can be brought back from the dead again, the "Frankenstein Motor".
At least its a cheaper older engine, and those are the ones you can usually bring back to life again without costing too much money, and probably get a few years of usage out of it.
If you have the time and patience, it would be like a hobby to work on it, but chances are it will probably run again, I have seen worse brought back from the "Dead" and they are running now.
ST1100A is offline
post #14 of 23 Old 02-02-2020, 06:27 AM Thread Starter
Likes (Received): 6
Thank you for all the advice,much appreciated.
Mt.Hood is online now
post #15 of 23 Old 02-05-2020, 10:24 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
What does the oil look like?
post #16 of 23 Old 02-06-2020, 03:06 PM Thread Starter
Likes (Received): 6
Finally had some time available to take a peek at the crank. Better looking then I was anticipating. Ready to pull the piston and look at the ring. db9938,here’s a shot of the oil.
post #17 of 23 Old 02-06-2020, 03:59 PM
Thanks (Received): 80
Likes (Given): 69
Likes (Received): 257
that looks pretty good to me. it will be interesting to see how the bore cleans up. with the piston out.
yardworks 31AH6WKF515
crazzywolfie is online now
post #18 of 23 Old 02-06-2020, 06:17 PM Thread Starter
Likes (Received): 6
Scoring on the piston and in the cylinder. More then likely from the removal of the piston. ****!
Sent from my iPad using Tapatalk
post #19 of 23 Old 02-06-2020, 06:27 PM
Likes (Given): 69
did you use any lube or penitrating oil while trying to remove it? definitely looks like it needed it
post #20 of 23 Old 02-06-2020, 07:41 PM Thread Starter
Likes (Received): 6
Yes I did
