Re-powered my MTD (98 5/24) - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-16-2014, 12:24 AM Thread Starter
dankicksass's Avatar
The Tecumseh on my snowblower gave up the ghost a couple weeks ago, blowing oil out the exhaust. I didn't want to rebuild it, never was really happy with the snowblower's power but I didn't want to buy new. I grabbed the nearest magazine and went to HF.com armed with a coupon for a fake Honda motor. The motor swap was easy, thanks to GustoGuy's pictures of his. I haven't done anything to the motor but take out the air filter - anything I really need to do? It runs pretty smooth as is. Seems I've lost support for the lamp on my unit though, any suggestions on how to remedy that? Thanks guys.
dankicksass is offline
post #2 of 12 Old 02-16-2014, 12:39 AM
Likes (Given): 213
Likes (Received): 304
Welcome to SBF Dan.
While there may be an aftermarket lighting coil for the Predator, I haven't heard of one.
I do know they don't come with one.
dbert is online now
post #3 of 12 Old 02-16-2014, 01:05 AM Thread Starter
I had never maintained the blower before. Cardinal sin, I'm sure, especially since I'm a technician by trade. Only thing I ever did was top off oil and gas, and continually adjusted the cables to make up for wear. So by the time the motor let go, I was down to just 2nd gear, no reverse, auger was stuck on. I guess I could have looked after it better. But now it's got the new motor, new belts, new and much larger Ariens skids, resurfaced transmission disc, new spring for auger release and drive belt tensioner, and on order a new cutting edge and rubber trans wheel. All transmission positions work, it throws snow like new, and I'm quite pleased overall.
post #4 of 12 Old 02-16-2014, 04:17 AM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 76
Likes (Received): 128
The Predator engine worked great in my machine too. I use it more now that the engine is finally reliable. I never really like the Tecumseh. Even when it was new it never had the power or the ease of starting that the Honda clone has.
GustoGuy is online now
post #5 of 12 Old 03-14-2014, 10:57 PM
Yup just repowered mine today with the Predator 212. Very easy changeover.
Skidder is offline
post #6 of 12 Old 09-16-2014, 10:22 PM
Thanks (Given): 67
Thanks (Received): 59
Likes (Given): 115
Likes (Received): 80
Has anyone had any luck in getting a head light to work off of a Preditor?
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #7 of 12 Old 09-16-2014, 11:29 PM
GustoGuy's Avatar
Thanks (Given): 47
Small LED bicycle lights will work. Some of them you can plug in and recharge them. Or you can run them with a small rechargeable battery on the snow blower. You can also buy a small belt driven generator to run the lights. High powered LED spotlight type of light would be a lot easier to do though
post #8 of 12 Old 09-30-2014, 11:27 AM
Is the light that much of a benefit?
Where I live, it is never pitch dark, especially when there is white stuff everywhere.
Of course some of you may live in the boondocks where there is no ambient light pollution coming from a nearby city.
Blaine B. is offline
post #9 of 12 Old 09-30-2014, 06:25 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Well, sometimes a little more light helps silhouette those pesky frozen newspapers.
post #10 of 12 Old 09-30-2014, 10:57 PM
GustoGuy's Avatar
Thanks (Given): 47
Here is a nice high powered rechargeble LED headlamp for a bicycle that will work. It lasts 180 minutes on full brightness per charge.
https://www.superbrightleds.com/cat/bicycle-led-lights/
