My Landmark Restoration Project - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 06-02-2014, 09:57 PM Thread Starter
My Landmark (MTD) Restoration is now complete. I had my machinist make a new impeller shaft, and cut a new keyway into the auger shaft. Installed new Impeller Bearing, belts, rebuilt and repack auger gearbox. Still had the original aluminum gear in good condition. Repaint and clean and lube every thing. Drilled holes into the axle and installed grease nipples in both sides as well as new axle bushings. Looking forward to using it next winter.
Hank
ID:	16185   Click image for larger version
Name:	Hank's Pictures 001.jpg
ID:	16193   Click image for larger version
Name:	Hank's Pictures 003.jpg
ID:	16201   Click image for larger version
Name:	Hank's Pictures 005.jpg
ID:	16209   Click image for larger version
Name:	Hank's Pictures 006.jpg
Name:	Hank's Pictures 007.jpg
1986 Landmark (MTD) 26" 2 stage with HM80
hankster1 is offline
post #2 of 14 Old 06-02-2014, 10:07 PM
it looks great. definitley not anything like the cxheap, flimsy crap that mtd makes today. are you planning to install an impeller kit?
post #3 of 14 Old 06-02-2014, 10:31 PM Thread Starter
It has a 14" Impeller, I could already throw the snow onto the roof of my house if I wanted to so I don"t think its necessary on this machine. I actually welded up some cracks in the lower corners of the auger housing. Thick heavy gauge steel. The impeller shaft is 7/8 shafting and the auger shaft is 1" I really liked this machine last winter so decided to fix it up nice.
Hank
post #4 of 14 Old 06-02-2014, 11:39 PM
Likes (Given): 26
Likes (Received): 7
Great work and result!
Fred9 is offline
post #5 of 14 Old 06-03-2014, 04:02 AM
Thanks (Given): 572
Thanks (Received): 747
Likes (Given): 4236
Likes (Received): 1655
My Craftsman has a 14" impeller and I know how much snow that sucker can eat and toss. Makes for one heck of a rooster tail. They are well worth fixing up as you have a tank when you're done.
You did an excellent job on that machine. The impeller kit is a nice modification if you get much wet heavy snow. Mine would sometimes clog but with the mod it doesn't. It made a difference on mine.
post #6 of 14 Old 06-03-2014, 08:50 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
Nice job.
liftoff1967 is offline
post #7 of 14 Old 06-03-2014, 11:40 PM
Hello Hankster,
Im in the process of redoing my 87 10hp 33in MTD Yardman. I hope it turns out as good as yours but I am just going to do a rattle can paint job this yr. What paint did you use and what is the orange color? Tony
pweerc is offline
post #8 of 14 Old 06-04-2014, 08:36 AM
looks like chevy orange
post #9 of 14 Old 06-04-2014, 11:37 AM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 326
Likes (Given): 3238
Likes (Received): 660
GREAT job on the restoration, looks better than new.
post #10 of 14 Old 06-04-2014, 05:58 PM
Likes (Given): 213
Likes (Received): 304
Very nice.
dbert is online now
