MTD 314 800 500 model - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-23-2014, 11:36 PM Thread Starter
Hello everyone-I am new to the forum, having just inherited this old snowblower. I am experienced working on small engines, and am looking forward to getting it running well.
It is a MTD 314 800 500, from the plate.
It has a Tecumseh 8 horse engine, HM80 1552425 Serial 31930
It has a leaking carb, and will not maintain idle. It runs out of fuel unless the primer bulb is continually pumped, indicating a fuel problem. I expect to need to do a carb clean or rebuild to fix this. It starts easily on full choke, and runs until it starves for fuel. Maybe also a sunken float. I will find new belts for it, as the old ones squeal, and it doesn't throw snow like it should.
I have not yet found a manual through an internet search. Any ideas?
mtd314 is offline
post #2 of 6 Old 11-23-2014, 11:46 PM
Normex's Avatar
Likes (Received): 82
Welcome to the forum. Good Luck for getting a manual but there is enough You Tubes to take care of your snow blower, DonyBoy is well regarded on the subject.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 6 Old 11-24-2014, 06:13 AM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1850
Likes (Received): 647
hello mtd314, welcome to SBF!! be sure to replace the fuel line
post #4 of 6 Old 11-24-2014, 06:38 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 566
Likes (Received): 263
Welcome to the forum. DonyBoy does have a video where he has to pump
the carb to keep the machine running. This video would be very good for your issue.
If you have just used the internet for the manual and not called MTD, I would call MTD and ask for their help. Prehaps they could send you one or tell you how to find one on the web.
Zavie is offline
post #5 of 6 Old 11-24-2014, 11:46 AM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 326
Likes (Given): 3238
Likes (Received): 660
Hello and welcome to the forum mtd314. Go to the MTD web site and enter model 314-800 into the model number box. I entered 8 dashes for the serial number since you didnít post yours. See if this is your machine.
PDF Manual Web Archive
Here is also the link to the engine manual if you need it. I hope this helps.
post #6 of 6 Old 12-09-2014, 02:01 PM
I second calling MTD if you haven't already. I was looking for a manual for a 1980 MTD snowbird and couldn't find one anywhere, called customer support and within 5 minutes had the manual in PDF form. In my case, I had to enter in the model number (318000) and just enter a "1" in the serial number field.
BigRedBird is offline
