Tecumseh Engine Swap - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 10-07-2013, 07:30 PM Thread Starter
Hello guys, just wondering if anyone knows of an 8HP direct replacement engine for a Tecumseh HM80-155444P. The problem I am having is locating an engine with 2 PTO's. Seems like all the new engines are single PTO. The snow blower is a 1992 MTD Snow Flite 8/26 model 312-640F500.
Thanks.
Brad
NWCanuck is offline
post #2 of 16 Old 10-07-2013, 07:46 PM
Blue Hill's Avatar
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Welcome to the forum Canuck!
I don't have an answer for you, but I'm sure several of the folks who hang out here will. It's a great place.
Larry
Blue Hill is offline
post #3 of 16 Old 10-07-2013, 08:16 PM
I don't know what the issue with your engine is (broken rod?)), but one other possibility is finding a single shaft HM80 and switching the camshaft and front cover from your old engine in. Not all engines are the same, but some will switch over. Could probably get away with HM80, HM90, HM100 and maybe even HMSK.
post #4 of 16 Old 10-07-2013, 08:49 PM Thread Starter
Thanks for the quick replies guys. No real issue here with the tecumseh engine just yet. I have spent around $100 on both the engine and the snow blower itself. The blower is in great shape but you kind of reach a point with these older machines where if something catastrophic happens like the Tecumseh throws a rod, is it really worth fixing? It seems like the Tecumseh parts are becoming harder and harder to find. It would be nice to have an engine from a manufacturer that is still in business.
NWCanuck is offline
post #5 of 16 Old 10-07-2013, 09:02 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 75
Likes (Received): 127
Since you have a dual shaft engine like I once did it can be converted over to a single shaft design provided you can flip the gear box and put the drive gear and friction wheel over to the other side. Since the cam shaft pulley which operates the drive rotates in the opposite direction as the engine does and at 1/2 the speed you will need to get a larger diameter drive plate like I did for my 1996 MTD 5/22 or you will have a real fast snow blower which is not a good thing. Check out my threads in the MTD forum. I replaced my engine with a Harbor freight 212cc 7hp engine and it runs great now and really tosses the snow. See my video under mrgustoguy on Youtube
GustoGuy is online now
post #6 of 16 Old 10-07-2013, 09:55 PM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Talking
I've seen a place on ebay that sells a briggs 900 series (I think its 8.5 HP) with dual shafts as a replacement for the Ariens rocket tillers. The orig HH70 tecumseh on the rockets also have dual shafts. Maybe it could be adapted to a snowblower application with some mods. If you search "ariens rocket pto" on ebay it should come right up. But they want over $430 bucks for it, so take good care of your current engine!
Ray 1962 10ML60 is offline
post #7 of 16 Old 10-08-2013, 12:29 AM
Simplicity Solid 22's Avatar
Have you replaced a lot of parts on your Tecumseh????
post #8 of 16 Old 10-08-2013, 01:42 AM Thread Starter
Thanks for all the replies. Funny you should ask Simplicity. I got this snow blower from my father because he found it hard to start. It was third hand to him and had originally belonged to his friends father. It was well taken care of by the original owner but not so much by my father (a spark plug and more oil kind of guy). He just bought a new MTD and was going to dispose of this one so I took it and have made it a pet project.
Lack of maintenance and TLC required some rust removal all around because this blower had been left outside on more than one occasion without a cover. The auger end of the blower required the most work.
1. The Auger housing was sanded and welded in corners because there were stress crack forming the area of the skid shoes and shave plate.
2. Front end was disassembled painted and grease.
3. New Belts all around the unit has two for the auger and one for the drive.
4. New Auger cable and pulley wheels, lube and grease all around including drive shafts which were bone dry.
5. New actuator at the control end for the chute. Plastic nub had broken off where the control meets the cables.
The Tecumseh engine had light rust on most of the cowling and covers. But runs smooth. Oil was very dirty so I drained that too while I was at it. Inside the crank case looks clean given the colour of the oil which had me worried.
I bought new fuel lines and linkages from the governor to throttle and from the governor to carb. I have taken all of the covers off and blower housing and have sanded and painted them. I also gave the cylinder head a cleaning and then a light coat high temp flat black to cover the oxidation up. I bought a carb rebuild kit and some new gaskets for the carb to manifold connections.
All I have left to do is rebuild the carb and put it all back together. So I have quite a bit of time invested maybe 24hrs but not a lot in parts which I was very surprised were still available given the age of both the snowblower and the engine. I would hate to do all this work and then have the Tecumseh throw a rod which I hear was the weak point of this engine. Then again a part of me would like to think this engine is over 20 years old and would have thrown it by now if it was a lemon. It would just be nice to know there is a one for one drop in replacement waiting out there for me when the time comes, but I think that ship has sailed. A shame when it does happen because the blower is in great shape.
ID:	2330   Click image for larger version
ID:	2338   Click image for larger version
NWCanuck is offline
post #9 of 16 Old 10-08-2013, 02:36 AM
Wow NW that is going to look like new!!!
post #10 of 16 Old 10-08-2013, 08:24 PM
td5771's Avatar
Likes (Received): 57
just keep your eyes open for an entire blower with something else wrong.
I just picked up a craftsman trac drive 8 hp (2 output shaft) 26 inch from the original owner. he took exceptional care of it and it shows however the shaft the drive pulley and friction plate ride on wore out the bearing and then the shaft to the point it wouldnt drive.
shaft is not available so I have to make it.
the whole machine was $125 and the engine is in perfect shape.
you just have to keep looking
td5771 is offline
