1978 MTD Snowflite shear pins grade 5 bolts? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-30-2015, 03:20 PM Thread Starter
I was looking at the shear pins on my snowblower and noticed that one is a grade 5 bolt. I went to get a "proper" pin today and discovered that many of the snowblowers, including the replacement pins for some of the bigger blowers, use grade 5 bolts (and are sold as shear pins). The guy at the shop said it was pretty common for bigger blowers to use grade 5s instead of lighter bolts. My blower is a 10/33--should I be using the grade 5 bolt?
Madroaster is offline
post #2 of 5 Old 01-30-2015, 04:04 PM
I would say probably not. The heavy duty Ariens use normal shear bolts. On the other hand Toro touts they don't need shear bolts and they do use grade 5 bolts. Or at least they used to. That doesn't sound good with MTD though.
post #3 of 5 Old 01-30-2015, 04:57 PM
Thanks (Given): 510
Thanks (Received): 681
Likes (Given): 3844
Likes (Received): 1478
Welcome to the forum Madroaster
The best thing to do is add the model and serial number of the machine so we can look it up and be sure what it calls for.
post #4 of 5 Old 01-30-2015, 05:55 PM
Thanks (Received): 348
Likes (Received): 1144
ALOHA from the frozen TUNDRA.:ee k:
post #5 of 5 Old 01-31-2015, 08:04 AM Thread Starter
It's a 318-960 I believe. The ID plate is missing. I contacted MTD and we narrowed it down to this based on the engine serial number. I have the manual and it doesn't specify beyond the dimensions of the bolt.
