Snowflite Model: 319-600 - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 16 Old 12-16-2013, 04:43 PM
Here's a link to the manual with parts list. The same unit was sold under several brand names as is the case with most MTD equipment, so you may find other manuals under various other brands
http://manuals.mtdproducts.com/mtd/DocGetter?doc=770-2404a.pdf
timothytim is offline
post #12 of 16 Old 01-28-2014, 04:31 AM Thread Starter
iwlu25's Avatar
Fuel issue?
After getting the old girl Reconditioned, I cleared the drive with 5 inches of snow. This was the first run. The engine ran fine for about 30 minutes and then stop running. The engine stopped running 4 times in a 3 hour run. Fuel feed issue I think. Maybe worn needle and seat.
Google Drive HS50-67175B Engine Link
iwlu25 is offline
post #13 of 16 Old 01-28-2014, 06:09 AM
Could be the needle was getting stuck closed, the fuel lines are swelling shut, the fuel cap vent it plugged, some junk is rattling around in the tank or carb and blocking things. Could be lots of issues.
post #14 of 16 Old 01-29-2014, 02:37 AM Thread Starter
iwlu25's Avatar
Thank you for the link timothytim
MTD Snowflite 319-600A
iwlu25 is offline
post #15 of 16 Old 03-15-2015, 08:54 PM
New here and found you guys with the same snowblower... I am needing a new scrape blade for the bottom any ideas where I can locate parts? ITs to old to get anything by model number or part number online from MTD
319-600A part number 370-5000
onlydirt is offline
post #16 of 16 Old 03-17-2015, 05:22 AM Thread Starter
iwlu25's Avatar
Do you mean the shave plate (Ref # 69 Part # 05622? I have a complete parts list for the 319-600A machine and all part numbers start with a 7, like 700-0000 or a 5 digit part number. Where did you get the 370-5000 part number from?
iwlu25 is offline
