Snowflite 5/24 Oil,Spark Plug & Model No. - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 11-14-2015, 04:00 PM Thread Starter
i collected a couple old Snow Flites 5/24
model number is partly rubbed off, i can read 314 550 _ _ 0 A054B
is this the model and serial number?
i need a few dealer parts, but can't enter the right model number.
need some carb linkage and the metal air boxes for both
what oil and spark plug for these ?
Name:	snow - Copy (800x449).jpg
red necking it is offline
post #2 of 11 Old 11-14-2015, 06:52 PM
Thanks (Received): 373
Likes (Received): 1326
More than likely that is the serial number. for oil I would use 10w30. fill it to the top of the hole. what does the old plug number read. use that number. ALOHA from the paradise city.
POWERSHIFT93 is online now
post #3 of 11 Old 11-14-2015, 07:03 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 401
Likes (Received): 641
i would go with 5w-30 synthetic, and research the engine model # for the recommended plug. jmo
Likes Grunt liked this post
post #4 of 11 Old 11-14-2015, 08:40 PM
Grunt's Avatar
Thanks (Given): 262
Thanks (Received): 323
Likes (Given): 3205
Likes (Received): 650
red necking it.
The 5hp Tecumseh motors take 21 ounces of 5w-30 oil for cold weather use. The spark plug is a Champion RJ17LM for a HS50 motor OR a Champion RJ19LM for a HSSK50 motor. I don't know which motor you have.
post #5 of 11 Old 11-15-2015, 10:49 AM Thread Starter
both engines are HS50's........
J8C in one , E3 TO in the other
new to this site,trying to save a couple bucks ,thanks for the help
post #6 of 11 Old 12-04-2015, 07:25 AM Thread Starter
any one have the part numbers for the drive and blower belts ?
post #7 of 11 Old 12-04-2015, 07:59 AM
Thanks (Given): 223
Thanks (Received): 294
Likes (Given): 1832
Likes (Received): 637
if you have the old belts take them to an ope shop and see if they can match up the belts. did you ever get a model number for your machines
post #8 of 11 Old 12-04-2015, 11:27 AM
Grunt's Avatar
Thanks (Given): 262
Likes (Given): 3205
Go to MTD's web site and enter 314550 in the model box, and A054B in the serial box to view the operator and parts list. I hope this is your machine.
PDF Manual Web Archive
post #9 of 11 Old 12-04-2015, 11:53 AM
Thanks (Given): 564
Thanks (Received): 742
Likes (Given): 4201
Likes (Received): 1635
Looks like they should be these:
Transmission belt: 754-0256
One source:
Auger belt:754-0257
If you're thinking of ordering them on line I'd make sure they are correct by measuring them or trying to get part numbers off them.
Thanks Grunt thanked for this post
post #10 of 11 Old 12-27-2015, 09:54 AM Thread Starter
thanks for all the help.
