1973 MTD Snow Flite part needed - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 11-23-2015, 11:57 PM Thread Starter
Hello out there. New to the forum. I have a 1973 MTD Snow Flite. Have had it for over 23 years. It originally was my Dads and I got it in early 1990's. It's a 26" Model No. 313-830. It actually has an A then two spaces B after the number. Tecumseh 8 hp. engine. I've got the Operating and Service Instructions which also lists the parts with diagrams and part numbers. Well, this year the old girl had enough and broke the Thrower axle. The original part number for that is 738-178. I'm looking for one and maybe some other parts if I get that. Otherwise I may be trying to build my own or see if a local machine shop can replicate. I'd like to keep it running and maybe someday hand down to my son. So for sentimental reasons I'd like to keep the old iron running. Any help will be appreciated in locating. Thanks.
jerbear is offline
post #2 of 12 Old 11-24-2015, 06:58 AM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1849
Likes (Received): 644
hello jerbear, I just stopped in to say welcome to SBF!!
Thanks jerbear thanked for this post
post #3 of 12 Old 11-24-2015, 09:21 AM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4224
Likes (Received): 1643
Welcome to the forum Jerbear
Is it the axle that drives the impeller ?? Does it have a keyway cut into it ??
post #4 of 12 Old 11-24-2015, 11:19 AM Thread Starter
Thanks for the welcome. It is the axle that drives the Thrower Paddle and could be called the impeller. There is a separate axle in front, the spiral axle which is driven by a chain (covered by a chain guard) attached to the thrower axle. It appears to be a solid axle. And broke where there is a score for a snap ring, in between the clutch assembly and the sprocket hub assembly.
jerbear is offline
post #5 of 12 Old 12-10-2015, 10:13 PM
Likes (Received): 10
it might be a job for a machine shop.. sounds t me like you may have those rare 2 stage with the impeller oriented differently than the masses.. might be hard to find..
good news is.. with a good machine shop.. you should be able to get this back into service without spending more than id questmate 100 or so
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
Likes Kiss4aFrog, jerbear liked this post
post #6 of 12 Old 12-10-2015, 10:36 PM
Thanks (Given): 572
Likes (Given): 4224
Machine shop should be able to weld it back together and machine it smooth or fabricate a new shaft for you.
I can't find anything with that part number
Likes jerbear liked this post
post #7 of 12 Old 12-10-2015, 11:08 PM
AriensProMike's Avatar
Thanks (Received): 19
Likes (Received): 58
Welcome jerbear!
Does your snow blower look like this one?
AriensProMike is offline
post #8 of 12 Old 12-10-2015, 11:18 PM
russkat's Avatar
Thanks (Received): 36
Likes (Given): 38
Likes (Received): 125
I think model 313-830 looks like this...
russkat is offline
post #9 of 12 Old 12-10-2015, 11:31 PM
Oh ok. That's too bad. I could have gave you the parts from this one. I did find one in the Boston area. Not sure were your located.
http://worcester.craigslist.org/grd/5335204842.html
post #10 of 12 Old 12-10-2015, 11:47 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Welcome, those legacy MTD's are solid machines, and it is a shame that parts are not regularly supported. The simplest solution to your dilemma will be to have one made, and replace all the bearings while you can. It should last you another 41 years, and if you have replacement bearings, another 41 years.
