installed New Auger Belt and it was EATEN!!! - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-29-2015, 08:15 PM Thread Starter
Hey.
So after 20 years I decided to replace my belts on my MTD 5.5 HP machine. I first took off the auger belt pretty easy. Then I noticed I had to disconnect the front of the machine from the back to get the drive belt off. Did so... thinking all was good. Put everything back together and then this happened. Loud screeching.... and the brand new teethed belt had no teeth in 30 seconds.
joefar75 is offline
post #2 of 6 Old 11-29-2015, 08:20 PM
Likes (Given): 467
Likes (Received): 480
Originally Posted by joefar75 View Post
Hey.
You may have the wrong belt for the aplication as they mostly do not have any "teeth".
Also I think something was not properly intalled back or something seized causing the noise and the belt issue.
post #3 of 6 Old 11-29-2015, 08:26 PM
Thanks (Received): 112
Likes (Received): 297
Also I think something was not properly installed back or something seized causing the noise and the belt issue.
Did the original belt(s) have teeth? Is the new belt the same length as the old belt, and where did you get the part number for the replacement?
Which belt lost it's teeth, auger or traction?
Work fascinates me.
skutflut is offline
post #4 of 6 Old 11-29-2015, 08:59 PM
Usually around the bottom of the impeller pulley there are little pegs to hold the belt on the bottom. Sometimes you can miss those on assembly and accidentally route the belt on top of them instead of under them. That will ruin a belt quickly.
Likes 43128 liked this post
post #5 of 6 Old 11-29-2015, 08:59 PM Thread Starter
Yes. Old Belt had teeth.
joefar75 is offline
post #6 of 6 Old 11-29-2015, 09:00 PM Thread Starter
THANK YOU!!!!! Hopefully that's it.
joefar75 is offline
