New Predator Motor Installed! - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-13-2013, 07:26 PM Thread Starter
Replaced the old 5 HP Tecumseh today on my Craftsman (some were made by MTD). That motor runs like a champ! Quiet, and very powerful. Made a few passes in 1st and 2nd gear (the old R1 and R2), and noticed that it slipped a bit? Wondering if its time to change the "rubber wheel" for lack of a better word? I'm not so sure I'm going to be able to change the gearbox and planetary gears around on this one. Looks a little different than the MTD's I've seen on here....
Craftsman 5/23 Snowblower
6.5 HP Predator Motor
geocachenut is offline
post #2 of 5 Old 12-13-2013, 08:12 PM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1853
Likes (Received): 647
congrats on the motor change. the rubber wheel is usually called a friction disc. how are the belts
post #3 of 5 Old 12-13-2013, 10:51 PM
69ariens's Avatar
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Your blower might be a murry blower.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #4 of 5 Old 12-13-2013, 11:15 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 76
Likes (Received): 130
Check the rubber on the friction disk to see if it has any chunks missing from it replace it if damaged or worn badly. Also clean the friction plate off well with alcohol or brake cleaner or carburetor cleaner sometimes they have grease or oil residue on it and that can make the drive slip. As to the belt you can adjust the tensioner a bit to help. If the belt is worn or glazed badly then replace with a power rated belt
GustoGuy is online now
post #5 of 5 Old 12-28-2013, 08:42 PM
Moar power!
Bain is offline
