Engine rebuild - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-20-2015, 09:56 PM Thread Starter
Engine rebuild
Hello, I have a 1997 Tecumseh hmsk100 10hp snowblower. I am in the process of rebuilding the engine. I have put in the new connecting rod and piston and have bolted it to the crankshaft. I just put the camshaft in and have lined up the timing marks correctly. When I go to turn the engine over to make sure everything is ok, the gears get very very hard to turn when the intake valve goes up. Is this normal for this to happen? I just want to make sure that everythings ok before I go through all the trouble of putting it back together, only to find out that I have to tear it down again. what do you guys think?
thanks!
shark56 is offline
post #2 of 11 Old 12-20-2015, 10:04 PM
Thanks (Given): 169
Thanks (Received): 305
Likes (Given): 426
Likes (Received): 1016
Never rebuilt one of those but it doesn't seem right. I'd double check all the components and make double sure everything is correct. Possible bent valve stem? Valve too long?
post #3 of 11 Old 12-20-2015, 10:12 PM
Thanks (Given): 572
Thanks (Received): 747
Likes (Given): 4237
Likes (Received): 1657
If the plug is out so you're not fighting compression it should have almost the same feel all the time. IMHO the valves don't give much resistance at all unless there is something binding like Micah pointed out.
How does it feel when it's on the exhaust stroke and opening up the exhaust valve ??
post #4 of 11 Old 12-20-2015, 10:22 PM Thread Starter
I do not have the sump cover on or the cylinder head yet, so I don't know if that might be part of the problem. I am simply just spinning the crankshaft. when I spin the shaft, the exhast valve gives little resistance and spins smoothly. when the intake valve begins to open, that's when I'm experiencing a lot of the resistance. Is this normal maybe because that is the power stroke?
shark56 is offline
post #5 of 11 Old 12-20-2015, 10:34 PM
Likes (Given): 467
Likes (Received): 480
If the cylinder head is not installed (it is not building compression), the crank should turn smoothly with very little resistance when lifting the valves.
Something is not right with the intake valve, you should inspect it closely. Did it get dropped? Is it bent?
YSHSfan is online now
post #6 of 11 Old 12-20-2015, 10:38 PM Thread Starter
I never removed the valves because I was not doing a complete engine rebuild. I only put in new piston rings and a new connecting rod. I cant think of any way how the valves could have been damaged, because they weren't removed.
shark56 is offline
post #7 of 11 Old 12-20-2015, 10:38 PM
94EG8's Avatar
Thanks (Received): 48
If the sump cover isn't on yet it will cause binding. You can put it on without the gasket and just stick a couple of bolts in it to try.
94EG8 is offline
post #8 of 11 Old 12-20-2015, 10:47 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Received): 94
plus 1
scrappy is online now
post #9 of 11 Old 12-20-2015, 10:59 PM
Likes (Given): 467
+1
I missed that part
post #10 of 11 Old 12-20-2015, 11:29 PM
Thanks (Received): 112
Likes (Received): 297
Just curious as to what prompted the rebuild. Since you are into the engine anyway, why not remove the valves and check them for wear, condition of valve seats, springs, etc. If you didn't remove the valves, you cannot be sure that the intake valve is not bent. Is there any signs of wear on the cam shaft lobes, either exhaust or intake? How about the lifters?
Work fascinates me.
skutflut is online now
